[mapserver-commits] r11301 - trunk/mapserver
Tue Mar 22 11:55:28 EDT 2011
Author: assefa
Date: 2011-03-22 08:55:28 -0700 (Tue, 22 Mar 2011)
New Revision: 11301
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/mapkml.cpp
   trunk/mapserver/mapkmlrenderer.cpp
KML: update code to reflect output changes. Fix true type symbols. (#3766)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-22 14:34:15 UTC (rev 11300)
+++ trunk/mapserver/HISTORY.TXT	2011-03-22 15:55:28 UTC (rev 11301)
@@ -15,6 +15,10 @@
 Current Version (SVN trunk):
+- KML: update code to reflect output changes. Fix true type symbols. (#3766)
+- SLD: Text Symbolizer now uses the new expression syntax (#3757)
 - WFS: correct bbox values for GetFeature with featureid request (#3761)
 - Mapscript Seg Fault on mapObj->getMetaData (#3738)
Modified: trunk/mapserver/mapkml.cpp
--- trunk/mapserver/mapkml.cpp	2011-03-22 14:34:15 UTC (rev 11300)
+++ trunk/mapserver/mapkml.cpp	2011-03-22 15:55:28 UTC (rev 11301)
@@ -118,10 +118,12 @@
     return MS_SUCCESS;
-int msRenderTruetypeSymbolKml(imageObj *img, double x, double y,
+int msRenderTruetypeSymbolKml(imageObj *image, double x, double y,
         symbolObj *symbol, symbolStyleObj *style)
-   return MS_SUCCESS;
+    KmlRenderer* renderer = getKmlRenderer(image);
+    renderer->renderTruetypeSymbol(image, x, y, symbol, style);
+    return MS_SUCCESS;
Modified: trunk/mapserver/mapkmlrenderer.cpp
--- trunk/mapserver/mapkmlrenderer.cpp	2011-03-22 14:34:15 UTC (rev 11300)
+++ trunk/mapserver/mapkmlrenderer.cpp	2011-03-22 15:55:28 UTC (rev 11301)
@@ -330,16 +330,9 @@
         BgColor = layer->map->imagecolor;
          xmlNewChild(DocNode, NULL, BAD_CAST "name", BAD_CAST layer->map->name);
+         aggFormat = msSelectOutputFormat( layer->map, "png24");
+         aggFormat->transparent = MS_TRUE;
-         for (int i=0; i<map->numoutputformats; i++)
-             outputFormatObj *iFormat = layer->map->outputformatlist[i];
-             if(!strcasecmp(iFormat->name,"png24"))
-                 aggFormat = iFormat;
-                 break;
     currentLayer = layer;
