[mapserver-commits] r11303 - trunk/mapserver
Tue Mar 22 15:33:11 EDT 2011
Author: assefa
Date: 2011-03-22 12:33:11 -0700 (Tue, 22 Mar 2011)
New Revision: 11303
   trunk/mapserver/HISTORY.TXT
   trunk/mapserver/maprendering.c
KML: fix rounding problem for point feautres (#3767)
Modified: trunk/mapserver/HISTORY.TXT
--- trunk/mapserver/HISTORY.TXT	2011-03-22 18:41:23 UTC (rev 11302)
+++ trunk/mapserver/HISTORY.TXT	2011-03-22 19:33:11 UTC (rev 11303)
@@ -15,6 +15,8 @@
 Current Version (SVN trunk):
+- KML: fix rounding problem for point feautres (#3767)
 - KML: update code to reflect output changes. Fix true type symbols. (#3766)
 - SLD: Text Symbolizer now uses the new expression syntax (#3757)
Modified: trunk/mapserver/maprendering.c
--- trunk/mapserver/maprendering.c	2011-03-22 18:41:23 UTC (rev 11302)
+++ trunk/mapserver/maprendering.c	2011-03-22 19:33:11 UTC (rev 11303)
@@ -739,7 +739,7 @@
          if(computeLabelStyle(&s,label,fontset,scalefactor) == MS_FAILURE) {
             return MS_FAILURE;
-         if(s.rotation == 0) {
+         if(s.rotation == 0 && !MS_RENDERER_KML(image->format)) {
             x = MS_NINT(labelPnt.x);
             y = MS_NINT(labelPnt.y);
          } else {
