[mapserver-commits] r11436 - trunk/docs/en/mapfile
Thu Mar 31 12:03:45 EDT 2011
Author: havatv
Date: 2011-03-31 09:03:45 -0700 (Thu, 31 Mar 2011)
New Revision: 11436
   trunk/docs/en/mapfile/style.txt
STYLE: Hard brackets required was missing a couple of places
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-03-31 15:15:41 UTC (rev 11435)
+++ trunk/docs/en/mapfile/style.txt	2011-03-31 16:03:45 UTC (rev 11436)
@@ -243,7 +243,8 @@
     You can also specify a gif or png filename. The path is relative to the
     location of the mapfile.
-    [*Attribute*] was introduced in version 5.6, to specify the symbol name
+    [*Attribute*] was introduced in version 5.6, to specify the symbol name.
+    The hard brackets [] are required.
 WIDTH [double|attribute]
@@ -265,6 +266,7 @@
       For its use with hatched lines, see Example#8 in the
       :ref:`symbology examples <sym_examples>`.
     - [*Attribute*] was added in version 5.2 to specify the item name in
-      the attribute table to use for the width value.
+      the attribute table to use for the width value. The hard brackets
+      [] are required.
     - Starting from version 5.4, the value can also be a fractional
       value (and not only integer).
