[mapserver-commits] r11437 - trunk/docs/en/mapfile
Thu Mar 31 12:26:59 EDT 2011
Author: havatv
Date: 2011-03-31 09:26:58 -0700 (Thu, 31 Mar 2011)
New Revision: 11437
   trunk/docs/en/mapfile/style.txt
STYLE: More detailed description for SIZE
Modified: trunk/docs/en/mapfile/style.txt
--- trunk/docs/en/mapfile/style.txt	2011-03-31 16:03:45 UTC (rev 11436)
+++ trunk/docs/en/mapfile/style.txt	2011-03-31 16:26:58 UTC (rev 11437)
@@ -200,14 +200,24 @@
 SIZE [double|attribute]
-    - Height, in layer SIZEUNITS, of the symbol/pattern to be used. Only useful with
-      scalable symbols. Default is 1. For symbols of Type HATCH, the SIZE is the
-      distance between hatched lines. For its use with hatched lines, see
-      Example#8 in the :ref:`symbology examples <sym_examples>`.
-    - [*Attribute*] was introduced in version 5.0, to specify the item name in
-      the attribute table to use for size values.  The hard brackets [] are
-      required.  For example, if your shapefile's DBF has a field named "MYSIZE"
-      that holds size values for each record, your STYLE object for
+    Height, in layer `SIZEUNITS`, of the symbol/pattern to be used.
+    Only useful with scalable symbols (:ref:`SYMBOL` `TYPE` ellipse,
+    hatch, pixmap, truetype, vector). Default is 1.0.
+    For scaling symbols (`SYMBOLSCALEDENOM` is specified for the
+    :ref:`LAYER`), `SIZE` gives the height, in layer `SIZEUNITS`,
+    of the symbol/pattern to be used at the map scale
+    1:`SYMBOLSCALEDENOM`.
+    - For symbols of `TYPE` `hatch`, the `SIZE` is the center to
+      center distance between the lines. For its use with hatched
+      lines, see Example#8 in the
+      :ref:`symbology examples <sym_examples>`.
+    - [*Attribute*] was introduced in version 5.0, to specify the
+      item name in the attribute table to use for size values.
+      The hard brackets [] are required.
+      For example, if your data set has an attribute named "MYSIZE"
+      that holds size values for each feature, your STYLE object for
       hatched lines might contain:
       .. code-block:: mapfile
@@ -221,8 +231,8 @@
         END
       The associated RFC document for this feature is :ref:`RFC19`.
-    - Starting from version 5.4, the value can also be a fractional value (and not
-      only integer).
+    - Starting from version 5.4, the value can also be a fractional
+      value (and not only integer).
 SIZEITEM [string]
