[mapserver-commits] r12514 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Mon Sep 5 03:12:58 EDT 2011
Author: havatv
Date: 2011-09-05 00:12:58 -0700 (Mon, 05 Sep 2011)
New Revision: 12514
   branches/branch-6-0/docs/en/mapfile/labelencoding.txt
   trunk/docs/en/mapfile/labelencoding.txt
Added some western language encodings to the notes in the labelencoding document (#3092) - links.
Modified: branches/branch-6-0/docs/en/mapfile/labelencoding.txt
--- branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-09-05 06:53:35 UTC (rev 12513)
+++ branches/branch-6-0/docs/en/mapfile/labelencoding.txt	2011-09-05 07:12:58 UTC (rev 12514)
@@ -9,8 +9,8 @@
 :Author: Jeff McKenna
 :Contact: jmckenna at gatewaygeomatics.com
-:Last Updated: $Date: 2011-08-29 14:26:49 +0200 (Mon, 29 Aug 2011) $
 :Revision: $Revision: 12506 $
+:Date: $Date: 2011-08-29 14:26:49 +0200 (Mon, 29 Aug 2011) $
 .. contents:: Table of Contents
     :depth: 3
@@ -30,7 +30,7 @@
 Related Links
-- MapServer `ticket:858 <http://trac.osgeo.org/mapserver/ticket/858/>`__
+- MapServer `ticket:858`_
 Requirements
@@ -50,10 +50,10 @@
    single: libiconv
 Mapserver uses GNU's libiconv library (
-http://www.gnu.org/software/libiconv/ ) to deal with encodings.  The
-libiconv web site has a list of supported encodings.  One can also use
-the "iconv -l" command on a system with libiconv installed to get the
-complete list of supported encodings on that specific system.
+`http://www.gnu.org/software/libiconv/`_ ) to deal with encodings.
+The libiconv web site has a list of supported encodings.  One can also
+use the "iconv -l" command on a system with libiconv installed to get
+the complete list of supported encodings on that specific system.
 So, theoretically, every string with an encoding system supported by
 libiconv can be displayed as labels in MapServer as long as it has a
@@ -85,7 +85,7 @@
 Since MapServer uses the libiconv library to handle encodings, you can
 check the list of supported encodings here:
 Unix users can also use the *iconv -l* command on a system with
 libiconv installed to get the complete list of supported encodings on
@@ -250,3 +250,7 @@
    also known as LATIN-2 - eastern European languages), CP1252
    (Microsoft Windows Latin alphabet encoding - English and some other
    Western languages).
+.. #### rST Link Section ####
+.. _`ticket:858`: http://trac.osgeo.org/mapserver/ticket/858/
+.. _`http://www.gnu.org/software/libiconv/`: http://www.gnu.org/software/libiconv/
Modified: trunk/docs/en/mapfile/labelencoding.txt
--- trunk/docs/en/mapfile/labelencoding.txt	2011-09-05 06:53:35 UTC (rev 12513)
+++ trunk/docs/en/mapfile/labelencoding.txt	2011-09-05 07:12:58 UTC (rev 12514)
@@ -9,8 +9,8 @@
     :depth: 3
@@ -30,7 +30,7 @@
 Related Links
 Requirements
@@ -50,10 +50,10 @@
    single: libiconv
@@ -85,7 +85,7 @@
@@ -250,3 +250,7 @@
    Western languages).
