[mapserver-commits] r12515 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Mon Sep 5 04:46:09 EDT 2011
Author: havatv
Date: 2011-09-05 01:46:09 -0700 (Mon, 05 Sep 2011)
New Revision: 12515
   branches/branch-6-0/docs/en/mapfile/expressions.txt
   trunk/docs/en/mapfile/expressions.txt
Added index entries (#4001) - expressions
Modified: branches/branch-6-0/docs/en/mapfile/expressions.txt
--- branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-09-05 07:12:58 UTC (rev 12514)
+++ branches/branch-6-0/docs/en/mapfile/expressions.txt	2011-09-05 08:46:09 UTC (rev 12515)
@@ -331,6 +331,9 @@
 input and return logical values. A logical expression is either 'true'
 or 'false'.
+.. index::
+   pair: Expressions; and
 * ( ( Expression1 ) AND ( Expression2 ) )
   ( ( Expression1 ) && ( Expression2 ) )
@@ -339,6 +342,9 @@
   Expression2) are true.
+.. index::
+   pair: Expressions; or
 * ( ( Expression1 ) OR ( Expression2 ) )
   ( ( Expression1 ) || ( Expression2 ) )
@@ -346,6 +352,9 @@
   returns true when at least one of the logical expressions (Expression1
   or Expression2) is true.
+.. index::
+   pair: Expressions; not
 * NOT ( Expression1 )
   ! ( Expression1 )
@@ -361,6 +370,9 @@
 Syntactically, a sting is something encapsulated in single or double
 quotes.
+.. index::
+   pair: Expressions; eq
 *  ( "String1" eq "String2" )
    ( "String1" == "String2" ) - deprecated since 6.0
@@ -373,24 +385,36 @@
    returns true when the strings are equal.  Case insensitive.
+.. index::
+   pair: Expressions; ne
 *  ( "String1" != "String2" )
    ( "String1" ne "String2" )
    returns true when the strings are not equal.
+.. index::
+   pair: Expressions; lt
 *  ( "String1" < "String2" )
    ( "String1" lt "String2" )
    returns true when "String1" is lexicographically smaller than "String2"
+.. index::
+   pair: Expressions; gt
 *  ( "String1" > "String2" )
    ( "String1" gt "String2" )
    returns true when "String1" is lexicographically larger than "String2".
+.. index::
+   pair: Expressions; le
 *  ( "String1" <= "String2" )
    ( "String1" le "String2" )
@@ -398,6 +422,9 @@
    returns true when "String1" is lexicographically smaller than or equal
    to "String2"
+.. index::
+   pair: Expressions; ge
 *  ( "String1" >= "String2" )
    ( "String1" ge "String2" )
@@ -405,6 +432,9 @@
    returns true when "String1" is lexicographically larger than or equal
    to "String2".
+.. index::
+   pair: Expressions; in
 *  ( "String1" IN "token1,token2,...,tokenN" )
    returns true when "String1" is equal to one of the given tokens.
@@ -436,6 +466,9 @@
 The basic element for arithmetic operations is the number.  Arithmetic
 operations that return numbers will be covered in the next section.
+.. index::
 *  ( n1 eq n2 )
    ( n1 == n2 ) - deprecated since 6.0
@@ -485,49 +518,97 @@
 Spatial expressions that return a logical value (GEOS)
+.. index::
 *  ( shape1 eq shape2 )
    returns true if shape1 and shape2 are equal
+.. index::
+   pair: Expressions; intersects
 *  ( shape1 intersects shape2 )
    returns true if shape1 and shape2 intersect
+   .. versionadded:: 6.0
+.. index::
+   pair: Expressions; disjoint
 *  ( shape1 disjoint shape2 )
    returns true if shape1 and shape2 are disjoint
+.. index::
+   pair: Expressions; touches
 *  ( shape1 touches shape2 )
    returns true if shape1 and shape2 touch
+.. index::
+   pair: Expressions; overlaps
 *  ( shape1 overlaps shape2 )
    returns true if shape1 and shape2 overlap
+.. index::
+   pair: Expressions; crosses
 *  ( shape1 crosses shape2 )
    returns true if shape1 and shape2 cross
+.. index::
+   pair: Expressions; within
 *  ( shape1 within shape2 )
    returns true if shape1 is within shape2
+.. index::
+   pair: Expressions; contains
 *  ( shape1 contains shape2 )
    returns true if shape1 contains shape2
+.. index::
+   pair: Expressions; dwithin
 *  ( shape1 dwithin shape2 )
    returns true if the distance between shape1 and shape2
    is equal to 0
+.. index::
+   pair: Expressions; beyond
 *  ( shape1 beyond shape2 )
    is greater than 0
 .. index::
    pair: Expressions; String operations
@@ -543,16 +624,25 @@
 Functions that return a string
+.. index::
+   pair: Expressions; tostring
 *  tostring ( n1, "Format1" )
    uses "Format1" to format the number n1 (C style formatting
    - sprintf).
+.. index::
+   pair: Expressions; commify
 *  commify ( "String1" )
    adds thousands separators (commas) to a long number to make it
    more readable
 .. index::
    pair: Expressions; String functions
@@ -560,6 +650,9 @@
 String functions that return a number
+.. index::
+   pair: Expressions; length
 *  length ( "String1" )
    returns the number of characters of "String1"
@@ -571,10 +664,15 @@
 Arithmetic operations and functions that return a number
+.. index::
+   pair: Expressions; round
 *  round ( n1 , n2 )
    returns n1 rounded to a multiple of n2: n2 * round(n1/n2)
 *  n1 + n2
    returns the sum of n1 and n2
@@ -625,14 +723,22 @@
 Spatial functions that return a number (GEOS)
+.. index::
+   pair: Expressions; area
 *  area ( shape1 )
    returns the area of shape1
 Spatial functions that return a shape (GEOS)
+.. index::
+   pair: Expressions; fromtext
 *  fromtext ( "String1" )
    returns the shape corresponding to String1 (WKT - well known text)
@@ -641,17 +747,29 @@
      fromText('POINT(500000 5000000)')
+.. index::
+   pair: Expressions; buffer
 *  buffer (shape1 , n1 )
    returns the shape that results when shape1 is buffered with
    bufferdistance n1
+.. index::
+   pair: Expressions; difference
 *  difference ( shape1 , shape2 )
    returns the shape that results when the common area of
    shape1 and shape2 is subtracted from shape1
 .. index::
    pair: Expressions; Temporal expressions
@@ -685,6 +803,9 @@
 For temporal values obtained this way, the following operations are
 supported:
+.. index::
 *  ( t1 eq t2 )
    ( t1 == t2 ) - deprecated since 6.0
@@ -693,30 +814,45 @@
    returns true when the times are equal.
+.. index::
 *  ( t1 != t2 )
    ( t1 ne t2 )
    returns true when the times are not equal.
+.. index::
 *  ( t1 < t2 )
    ( t1 lt t2 )
    returns true when t1 is earlier than t2
+.. index::
 *  ( t1 > t2 )
    ( t1 gt t2 )
    returns true when t1 is later than t2.
+.. index::
 *  ( t1 <= t2 )
    ( t1 le t2 )
    returns true when t1 is earlier than or equal to t2
+.. index::
 *  ( t1 >= t2 )
    ( t1 ge t2 )
Modified: trunk/docs/en/mapfile/expressions.txt
--- trunk/docs/en/mapfile/expressions.txt	2011-09-05 07:12:58 UTC (rev 12514)
+++ trunk/docs/en/mapfile/expressions.txt	2011-09-05 08:46:09 UTC (rev 12515)
@@ -331,6 +331,9 @@
 or 'false'.
+.. index::
@@ -339,6 +342,9 @@
+.. index::
@@ -346,6 +352,9 @@
+.. index::
   ! ( Expression1 )
@@ -361,6 +370,9 @@
 quotes.
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
@@ -398,6 +422,9 @@
    to "String2"
+.. index::
@@ -405,6 +432,9 @@
    to "String2".
+.. index::
@@ -436,6 +466,9 @@
+.. index::
 *  ( n1 eq n2 )
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
+.. index::
    is equal to 0
+.. index::
    is greater than 0
 .. index::
+.. index::
    - sprintf).
+.. index::
    more readable
 .. index::
@@ -560,6 +650,9 @@
+.. index::
+.. index::
 *  round ( n1 , n2 )
 *  n1 + n2
+.. index::
 *  area ( shape1 )
+.. index::
+.. index::
    bufferdistance n1
+.. index::
 .. index::
@@ -685,6 +803,9 @@
 supported:
+.. index::
 *  ( t1 eq t2 )
+.. index::
 *  ( t1 != t2 )
    ( t1 ne t2 )
+.. index::
 *  ( t1 < t2 )
    ( t1 lt t2 )
+.. index::
 *  ( t1 > t2 )
    ( t1 gt t2 )
+.. index::
 *  ( t1 <= t2 )
    ( t1 le t2 )
+.. index::
 *  ( t1 >= t2 )
    ( t1 ge t2 )
