[mapserver-commits] r12527 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Tue Sep 6 17:01:22 EDT 2011
Author: havatv
Date: 2011-09-06 14:01:22 -0700 (Tue, 06 Sep 2011)
New Revision: 12527
   branches/branch-6-0/docs/en/mapfile/xml_mapfile.txt
   trunk/docs/en/mapfile/xml_mapfile.txt
Added index entries (#4001) - xml_mapfile
Modified: branches/branch-6-0/docs/en/mapfile/xml_mapfile.txt
--- branches/branch-6-0/docs/en/mapfile/xml_mapfile.txt	2011-09-06 20:50:05 UTC (rev 12526)
+++ branches/branch-6-0/docs/en/mapfile/xml_mapfile.txt	2011-09-06 21:01:22 UTC (rev 12527)
@@ -1,3 +1,8 @@
+.. index::
+   single: XML Mapfile support
+.. _xml_mapfile:
 XML Mapfile support
@@ -8,6 +13,12 @@
 to a text mapfile in a temporary file on disk, then process the
 mapfile normally.
+.. index::
+   single: libxslt
+.. index::
+   single: libexslt
 New Dependencies
 * libxslt
@@ -29,6 +40,9 @@
 Usage:
+.. index::
+   single: MS_XMLMAPFILE_XSLT
 In order to enable this feature, set the MS_XMLMAPFILE_XSLT
 environment variable to point to the location of the XSLT to use for
 the XML->text mapfile conversion. e.g. in Apache:
Modified: trunk/docs/en/mapfile/xml_mapfile.txt
--- trunk/docs/en/mapfile/xml_mapfile.txt	2011-09-06 20:50:05 UTC (rev 12526)
+++ trunk/docs/en/mapfile/xml_mapfile.txt	2011-09-06 21:01:22 UTC (rev 12527)
@@ -1,3 +1,8 @@
+.. index::
+.. _xml_mapfile:
 XML Mapfile support
@@ -8,6 +13,12 @@
 mapfile normally.
+.. index::
+   single: libxslt
+.. index::
+   single: libexslt
 New Dependencies
 * libxslt
@@ -29,6 +40,9 @@
 Usage:
+.. index::
