[mapserver-commits] r12528 - trunk/mapserver/mapcache
Wed Sep 7 07:27:30 EDT 2011
Author: tbonfort
Date: 2011-09-07 04:27:30 -0700 (Wed, 07 Sep 2011)
New Revision: 12528
   trunk/mapserver/mapcache/configure
   trunk/mapserver/mapcache/configure.in
check for pixman version >= 0.13.2
Modified: trunk/mapserver/mapcache/configure
--- trunk/mapserver/mapcache/configure	2011-09-06 21:01:22 UTC (rev 12527)
+++ trunk/mapserver/mapcache/configure	2011-09-07 11:27:30 UTC (rev 12528)
@@ -4602,15 +4602,19 @@
 fi
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for Pixman" >&5
+$as_echo_n "checking for Pixman... " >&6; }
     if test "$with_pixman" = "no" -o "$with_pixman" = "" ; then
-      { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
-$as_echo "no" >&6; }
+      { $as_echo "$as_me:${as_lineno-$LINENO}: result: disabled" >&5
+$as_echo "disabled" >&6; }
       PIXMAN_CONFIG="no"
     else
         if test -z "$PKGCONFIG"; then
             as_fn_error $? "pixman support requested, but pkg-config not found/configured" "$LINENO" 5
         fi
         if test "$with_pixman" = "yes" ; then
+            { $as_echo "$as_me:${as_lineno-$LINENO}: result: searching default locations" >&5
+$as_echo "searching default locations" >&6; }
             { $as_echo "$as_me:${as_lineno-$LINENO}: checking for pixman pkg-config entry" >&5
 $as_echo_n "checking for pixman pkg-config entry... " >&6; }
             `$PKGCONFIG --silence-errors -- pixman >> /dev/null`
@@ -4629,7 +4633,14 @@
                fi
             fi
         else
-          PIXMAN_CONFIG=$with_pixman
+          `$PKGCONFIG $with_pixman`
+          if test $? -eq 0 ; then
+            { $as_echo "$as_me:${as_lineno-$LINENO}: result: using supplied pkg-config definition $with_pixman" >&5
+$as_echo "using supplied pkg-config definition $with_pixman" >&6; }
+            PIXMAN_CONFIG=$with_pixman
+          else
+            as_fn_error $? "failed to use $with_pixman" "$LINENO" 5
+          fi
         fi
     fi
@@ -4642,9 +4653,25 @@
       PIXMAN_INC=
       PIXMAN_LIB=
     else
-      PIXMAN_ENABLED="-DUSE_PIXMAN"
-      PIXMAN_LIB=`$PKGCONFIG --libs $PIXMAN_CONFIG`
-      PIXMAN_INC=`$PKGCONFIG --cflags $PIXMAN_CONFIG`
+      { $as_echo "$as_me:${as_lineno-$LINENO}: checking if pixman version is >= 0.13.2" >&5
+$as_echo_n "checking if pixman version is >= 0.13.2... " >&6; }
+      PIXMAN_VERSION=`$PKGCONFIG --modversion -- "$PIXMAN_CONFIG"`
+      { $as_echo "$as_me:${as_lineno-$LINENO}: result: $PIXMAN_VERSION" >&5
+$as_echo "$PIXMAN_VERSION" >&6; }
+      `$PKGCONFIG --silence-errors -- "$PIXMAN_CONFIG >= 0.13.2" >> /dev/null`
+         PIXMAN_ENABLED="-DUSE_PIXMAN"
+         PIXMAN_LIB=`$PKGCONFIG --libs $PIXMAN_CONFIG`
+         PIXMAN_INC=`$PKGCONFIG --cflags $PIXMAN_CONFIG`
+      else
+         { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: pixman support has been disabled because your version is too old.
+                      full WMS will use the internal (usually slower) image merging functions" >&5
+$as_echo "$as_me: WARNING: pixman support has been disabled because your version is too old.
+                      full WMS will use the internal (usually slower) image merging functions" >&2;}
+         PIXMAN_ENABLED=
+         PIXMAN_INC=
+         PIXMAN_LIB=
+      fi
     fi
     PIXMAN_ENABLED=$PIXMAN_ENABLED
@@ -5107,8 +5134,8 @@
 $as_echo_n "checking for gdal-config usability in $with_gdal... " >&6; }
           if test -x "$with_gdal"; then
              GDALCONFIG=$with_gdal
-             { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
+             { $as_echo "$as_me:${as_lineno-$LINENO}: result: ok" >&5
+$as_echo "ok" >&6; }
           else
              as_fn_error $? "$with_gdal not found or not executable" "$LINENO" 5
           fi
Modified: trunk/mapserver/mapcache/configure.in
--- trunk/mapserver/mapcache/configure.in	2011-09-06 21:01:22 UTC (rev 12527)
+++ trunk/mapserver/mapcache/configure.in	2011-09-07 11:27:30 UTC (rev 12528)
@@ -195,14 +195,16 @@
         [with_pixman=yes])
+    AC_MSG_CHECKING(for Pixman)
-      AC_MSG_RESULT(no)
+      AC_MSG_RESULT(disabled)
       PIXMAN_CONFIG="no"
     else
             AC_MSG_ERROR([pixman support requested, but pkg-config not found/configured])
         fi
+            AC_MSG_RESULT(searching default locations)
             AC_MSG_CHECKING(for pixman pkg-config entry)
@@ -218,7 +220,13 @@
                fi
             fi
         else
+            AC_MSG_RESULT([using supplied pkg-config definition $with_pixman])
+          else
+            AC_MSG_ERROR([failed to use $with_pixman])
+          fi
         fi
     fi
@@ -229,9 +237,21 @@
       PIXMAN_INC=
       PIXMAN_LIB=
     else
+      AC_MSG_CHECKING([if pixman version is >= 0.13.2])
+      AC_MSG_RESULT([$PIXMAN_VERSION])
+      else
+         AC_MSG_WARN([pixman support has been disabled because your version is too old.
+                      full WMS will use the internal (usually slower) image merging functions])
+         PIXMAN_ENABLED=
+         PIXMAN_INC=
+         PIXMAN_LIB=
+      fi
     fi
     AC_SUBST(PIXMAN_ENABLED,$PIXMAN_ENABLED)
     AC_SUBST(PIXMAN_INC,$PIXMAN_INC)
@@ -491,7 +511,7 @@
           AC_MSG_CHECKING(for gdal-config usability in $with_gdal)
-             AC_MSG_RESULT(yes)
+             AC_MSG_RESULT(ok)
           else
              AC_MSG_ERROR($with_gdal not found or not executable)
           fi
