[mapserver-commits] r12595 - branches/branch-6-0/docs/en trunk/docs/en
Wed Sep 28 17:08:35 EDT 2011
Author: havatv
Date: 2011-09-28 14:08:35 -0700 (Wed, 28 Sep 2011)
New Revision: 12595
   branches/branch-6-0/docs/en/errors.txt
   trunk/docs/en/errors.txt
Added the msWMSLoadGetMapParams(): WMS server error to the errors document (#3055), small addition.
Modified: branches/branch-6-0/docs/en/errors.txt
--- branches/branch-6-0/docs/en/errors.txt	2011-09-28 21:03:11 UTC (rev 12594)
+++ branches/branch-6-0/docs/en/errors.txt	2011-09-28 21:08:35 UTC (rev 12595)
@@ -439,4 +439,5 @@
 service allows.
 To increase the maximum map width and height for the service, use the
-MAXSIZE parameter of the :ref:`MAP` object.
+MAXSIZE parameter of the :ref:`MAP` object.  Producing larger map
+images requires more processing power and more memory, so take care.
Modified: trunk/docs/en/errors.txt
--- trunk/docs/en/errors.txt	2011-09-28 21:03:11 UTC (rev 12594)
+++ trunk/docs/en/errors.txt	2011-09-28 21:08:35 UTC (rev 12595)
@@ -439,4 +439,5 @@
 service allows.
