[mapserver-commits] r12596 - branches/branch-6-0/docs/en trunk/docs/en
Wed Sep 28 17:27:19 EDT 2011
Author: havatv
Date: 2011-09-28 14:27:18 -0700 (Wed, 28 Sep 2011)
New Revision: 12596
   branches/branch-6-0/docs/en/errors.txt
   trunk/docs/en/errors.txt
Added index entries (#4001) - errors
Modified: branches/branch-6-0/docs/en/errors.txt
--- branches/branch-6-0/docs/en/errors.txt	2011-09-28 21:08:35 UTC (rev 12595)
+++ branches/branch-6-0/docs/en/errors.txt	2011-09-28 21:27:18 UTC (rev 12596)
@@ -1,3 +1,6 @@
+.. index::
+   single: Errors
 .. _errors:
@@ -5,6 +8,9 @@
+.. index::
+   pair: Error; drawEPP(): EPPL7 support is not available
@@ -40,6 +46,32 @@
   the getmap request.
+.. index::
+   pair: Error; loadLayer(): Unknown identifier. Maximum number of classes reached
+loadLayer(): Unknown identifier. Maximum number of classes reached
+Error displayed when attempting to draw a layer with a large number of classes.
+This error states that MapServer has reached its limit for the maximum number
+of classes for the layer. This maximum can be modified in the MapServer
+source, and can then be re-compiled. *map.h* contains the default values, and
+below are the defaults for MapServer 4.10 and 4.8:
+  #define MS_MAXCLASSES 250
+  #define MS_MAXSTYLES 5
+  #define MS_MAXLAYERS 200
+.. note::
+    This limitation was corrected in MapServer 5.0 and should no longer be a
+    problem.
+.. index::
+   pair: Error; loadMapInternal(): Given map extent is invalid
@@ -115,81 +147,26 @@
     The EXTENT in a mapfile must be in the same units as the :ref:`MAP` -level
     :ref:`PROJECTION`.
-msSaveImageGD(): Unable to access file
+.. index::
+   pair: Error; msGetLabelSize(): Requested font not found
-Error displayed when attempting to display map image.
-This error is displayed if MapServer cannot display the map image.  There are
-several things to check:
-- IMAGEPATH and IMAGEURL parameters in mapfile are valid
-- In CGI mode, any IMAGEPATH and IMAGEURL variables set in the init pages
-  are valid
-- Linux/Unix users should verify that the web user has permissions to
-  write to the IMAGEPATH
-msLoadMap(): Failed to open map file
+msGetLabelSize(): Requested font not found
-Error displayed when trying to display map image.
+Error displayed when attempting to display a specific font.
-The message tells you that MapServer cannot find mapfile.  Verify that you have
-specified the correct path to the mapfile.  Linux/Unix users should make sure
-that the web user has access permissions to the mapfile path as well.
+This message tells you that MapServer cannot find specified font.
-The error message states where MapServer thinks the mapfile is:
-   [MapServer Error]: msLoadMap(): (D:/ms4w/apps/blah/blah.map)
-   Failed to open map file D:/ms4w/apps/blah/blah.map
+   Make sure that the font is properly referenced in the FONTSET lookup file.
-msQueryByPoint: search returned no results
+.. seealso::
+    :ref:`FONTSET`
-Error displayed when a feature is known to exist at that location.
+.. index::
+   pair: Error; msLoadFontset(): Error opening fontset
-The query feature requires a TEMPLATE object in the :ref:`CLASS` object of
-your :ref:`LAYER` definition. The value points to a html fragment using
-MapServer template syntax.
-Example MapFile fragment:
-      LAYER
-        NAME "Parcel9"
-        TYPE POLYGON
-        STATUS OFF
-        DATA "Parcels/area09_parcels"
-        CLASS
-          STYLE
-            OUTLINECOLOR 128 128 128
-            COLOR 153 205 255
-          END
-          TEMPLATE "templates/Parcels/area09_parcels.html"
-        END
-        HEADER "templates/Parcels/area09_parcels_header.html"
-        FOOTER "templates/Parcels/area09_parcels_footer.html"
-      END
-Example Template:
-  <tr>
-    <td>[lrn]</td>
-    <td>[PIN]</td>
-  </tr>
-The [lrn] is a special keyword that indicates the resulting line
-number which starts at 1. [PIN] is the name of a feature attribute.
@@ -205,123 +182,28 @@
 .. seealso::
     :ref:`FONTSET`
-msGetLabelSize(): Requested font not found
+.. index::
+   pair: Error; msLoadMap(): Failed to open map file
-Error displayed when attempting to display a specific font.
-This message tells you that MapServer cannot find specified font.
-   Make sure that the font is properly referenced in the FONTSET lookup file.
-.. seealso::
-    :ref:`FONTSET`
-loadLayer(): Unknown identifier. Maximum number of classes reached
+msLoadMap(): Failed to open map file
-Error displayed when attempting to draw a layer with a large number of classes.
+Error displayed when trying to display map image.
-This error states that MapServer has reached its limit for the maximum number
-of classes for the layer. This maximum can be modified in the MapServer
-source, and can then be re-compiled. *map.h* contains the default values, and
-below are the defaults for MapServer 4.10 and 4.8:
+The message tells you that MapServer cannot find mapfile.  Verify that you have
+specified the correct path to the mapfile.  Linux/Unix users should make sure
+that the web user has access permissions to the mapfile path as well.
+The error message states where MapServer thinks the mapfile is:
-  #define MS_MAXCLASSES 250
-  #define MS_MAXSTYLES 5
-  #define MS_MAXLAYERS 200
-.. note::
-    This limitation was corrected in MapServer 5.0 and should no longer be a
-    problem.
-msReturnPage(): Web application error. Malformed template name
-This error may occur when you are attempting to use a URL template for a
-query. The issue is that URL templates are only allowed for query modes that
-return only one result (e.g. query or itemquery)
-You can only use a URL template for a query in mode=query or mode=itemquery.
-If you try it with mode=nquery or mode=itemnquery, you will get the error:
-    Content-type: text/html msReturnPage(): Web application error. Malformed template name
-.. seealso::
-    :ref:`cgi_controls`
+   [MapServer Error]: msLoadMap(): (D:/ms4w/apps/blah/blah.map)
+   Failed to open map file D:/ms4w/apps/blah/blah.map
-Unable to load dll (:ref:`MapScript`)
+.. index::
+   pair: Error; msProcessProjection(): no options found in 'init' file
-One of the dll-s could not be loaded that mapscript.dll depends on.
-You can get this problem on Windows and in most cases it can be dedicated to a
-missing or an unloadable shared library. The error message talks about
-mapscript.dll but surely one or more of the dll-s are missing that libmap.dll
-depends on. So firstly you might want to check for the dependencies of your
-libmap.dll in your application directory. You can use the Visual Studio
-Dependency Walker to accomplish this task. You can also use a file monitoring
-tool (like SysInternal's filemon) to detect the dll-s that could not be
-loaded. I propose to store all of the dll-s required by your application in
-the application folder. If you can run the mapscript sample applications
-properly your compilation might be correct and all of the dlls are available.
-C#-specific information
-You may find that the mapscript C# interface behaves differently for the
-desktop and the ASP.NET applications. Although you can run the drawmap sample
-correctly you may encounter the dll loading problem with the ASP.NET
-applications. When creating an ASP.NET project your application folder will be
-'\Inetpub\wwwroot\[YourApp]\bin' by default. The host process of the
-application will aspnet_wp.exe or w3wp.exe depending on your system. The
-application will run under a different security context than the interactive
-user (under the context of the ASPNET user by default). When placing the dll-s
-outside of your application directory you should consider that the PATH
-environment variable may differ between the interactive and the ASPNET user
-and/or you may not have enough permission to access a dll outside of your
-application folder.
-msProcessProjection(): Projection library error.major axis or radius = 0 not given
-Error displayed when attempting to specify projection parameters.
-Since MapServer 4.0, you are required to specify the ellipsoid for the
-projection.  Omitting this ellipsoid parameter in later MapServer
-versions will cause this error.
-Valid Examples
-4.0 and newer:
-.. code-block:: mapfile
-      PROJECTION
-        "proj=latlong"
-        "ellps=WGS84"
-      END
-before MapServer 4.0:
-      PROJECTION
-        "proj=latlong"
-      END
-.. seealso::
-    :ref:`PROJECTION` and http://spatialreference.org
@@ -337,6 +219,9 @@
 .. seealso::
+.. index::
+   pair: Error; msProcessProjection(): No such file or directory
@@ -383,6 +268,46 @@
       SetEnv PROJ_LIB C:/somedir/proj/nad/
+.. index::
+   pair: Error; msProcessProjection(): Projection library error.major axis or radius = 0 not given
+msProcessProjection(): Projection library error.major axis or radius = 0 not given
+Error displayed when attempting to specify projection parameters.
+Since MapServer 4.0, you are required to specify the ellipsoid for the
+projection.  Omitting this ellipsoid parameter in later MapServer
+versions will cause this error.
+Valid Examples
+4.0 and newer:
+.. code-block:: mapfile
+      PROJECTION
+        "proj=latlong"
+        "ellps=WGS84"
+      END
+before MapServer 4.0:
+      PROJECTION
+        "proj=latlong"
+      END
+.. seealso::
+    :ref:`PROJECTION` and http://spatialreference.org
+.. index::
+   pair: Error; msQueryByPoint: search returned no results
@@ -429,6 +354,45 @@
 .. index::
+   pair: Error; msReturnPage(): Web application error. Malformed template name
+msReturnPage(): Web application error. Malformed template name
+This error may occur when you are attempting to use a URL template for a
+query. The issue is that URL templates are only allowed for query modes that
+return only one result (e.g. query or itemquery)
+You can only use a URL template for a query in mode=query or mode=itemquery.
+If you try it with mode=nquery or mode=itemnquery, you will get the error:
+    Content-type: text/html msReturnPage(): Web application error. Malformed template name
+.. seealso::
+    :ref:`cgi_controls`
+.. index::
+   pair: Error; msSaveImageGD(): Unable to access file
+msSaveImageGD(): Unable to access file
+Error displayed when attempting to display map image.
+This error is displayed if MapServer cannot display the map image.  There are
+several things to check:
+- IMAGEPATH and IMAGEURL parameters in mapfile are valid
+- In CGI mode, any IMAGEPATH and IMAGEURL variables set in the init pages
+  are valid
+- Linux/Unix users should verify that the web user has permissions to
+  write to the IMAGEPATH
+.. index::
    pair: Error; msWMSLoadGetMapParams(): WMS server error
 msWMSLoadGetMapParams(): WMS server error. Image Size out of range, WIDTH and HEIGHT must be between 1 and 2048 pixels
@@ -441,3 +405,38 @@
 To increase the maximum map width and height for the service, use the
 MAXSIZE parameter of the :ref:`MAP` object.  Producing larger map
 images requires more processing power and more memory, so take care.
+.. index::
+   pair: Error; Unable to load dll
+Unable to load dll (:ref:`MapScript`)
+One of the dll-s could not be loaded that mapscript.dll depends on.
+You can get this problem on Windows and in most cases it can be dedicated to a
+missing or an unloadable shared library. The error message talks about
+mapscript.dll but surely one or more of the dll-s are missing that libmap.dll
+depends on. So firstly you might want to check for the dependencies of your
+libmap.dll in your application directory. You can use the Visual Studio
+Dependency Walker to accomplish this task. You can also use a file monitoring
+tool (like SysInternal's filemon) to detect the dll-s that could not be
+loaded. I propose to store all of the dll-s required by your application in
+the application folder. If you can run the mapscript sample applications
+properly your compilation might be correct and all of the dlls are available.
+C#-specific information
+You may find that the mapscript C# interface behaves differently for the
+desktop and the ASP.NET applications. Although you can run the drawmap sample
+correctly you may encounter the dll loading problem with the ASP.NET
+applications. When creating an ASP.NET project your application folder will be
+'\Inetpub\wwwroot\[YourApp]\bin' by default. The host process of the
+application will aspnet_wp.exe or w3wp.exe depending on your system. The
+application will run under a different security context than the interactive
+user (under the context of the ASPNET user by default). When placing the dll-s
+outside of your application directory you should consider that the PATH
+environment variable may differ between the interactive and the ASPNET user
+and/or you may not have enough permission to access a dll outside of your
+application folder.
Modified: trunk/docs/en/errors.txt
--- trunk/docs/en/errors.txt	2011-09-28 21:08:35 UTC (rev 12595)
+++ trunk/docs/en/errors.txt	2011-09-28 21:27:18 UTC (rev 12596)
@@ -1,3 +1,6 @@
+.. index::
+   single: Errors
 .. _errors:
@@ -5,6 +8,9 @@
+.. index::
@@ -40,6 +46,32 @@
   the getmap request.
+.. index::
+.. note::
+    problem.
+.. index::
     :ref:`PROJECTION`.
+.. index::
-  are valid
+.. seealso::
+    :ref:`FONTSET`
+.. index::
-      LAYER
-        NAME "Parcel9"
-        TYPE POLYGON
-        STATUS OFF
-        CLASS
-          STYLE
-            COLOR 153 205 255
-          END
-        END
-      END
-Example Template:
-  <tr>
-    <td>[lrn]</td>
-    <td>[PIN]</td>
-  </tr>
 .. seealso::
     :ref:`FONTSET`
+.. index::
-.. seealso::
-    :ref:`FONTSET`
-.. note::
-    problem.
-.. seealso::
+.. index::
-Valid Examples
-4.0 and newer:
-      PROJECTION
-        "proj=latlong"
-        "ellps=WGS84"
-      END
-      PROJECTION
-        "proj=latlong"
-      END
-.. seealso::
@@ -337,6 +219,9 @@
 .. seealso::
+.. index::
+.. index::
+Valid Examples
+4.0 and newer:
+      PROJECTION
+        "proj=latlong"
+        "ellps=WGS84"
+      END
+      PROJECTION
+        "proj=latlong"
+      END
+.. seealso::
+.. index::
 .. index::
+.. seealso::
+.. index::
+  are valid
+.. index::
+.. index::
