[mapserver-commits] r12597 - branches/branch-6-0/docs/en/ogc trunk/docs/en/ogc
Wed Sep 28 18:36:48 EDT 2011
Author: havatv
Date: 2011-09-28 15:36:48 -0700 (Wed, 28 Sep 2011)
New Revision: 12597
   branches/branch-6-0/docs/en/ogc/wms_server.txt
   trunk/docs/en/ogc/wms_server.txt
Improvement of the wms_server document - templates, gml output (#3208).
Modified: branches/branch-6-0/docs/en/ogc/wms_server.txt
--- branches/branch-6-0/docs/en/ogc/wms_server.txt	2011-09-28 21:27:18 UTC (rev 12596)
+++ branches/branch-6-0/docs/en/ogc/wms_server.txt	2011-09-28 22:36:48 UTC (rev 12597)
@@ -68,9 +68,11 @@
    - text/plain output with attribute info.
-   - text/html output using MapServer query templates specified in the CLASS
-     template parameter. The MIME type returned by the Class templates defaults
-     to text/html and can be controlled using the metadata "wms_feature_info_mime_type".
+   - text/html output using MapServer query templates (see
+     :ref:`template`) specified in the :ref:`CLASS` TEMPLATE parameter
+     (the filename has to have an .html extension).  The MIME type
+     returned by the Class templates defaults to text/html and can be
+     controlled using the metadata "wms_feature_info_mime_type".
    - application/vnd.ogc.gml, GML.1 or GML for GML features.
@@ -169,7 +171,7 @@
   - Layers set to STATUS DEFAULT will always be sent to the client.
   - Layers set to STATUS ON or STATUS OFF can be requested by the client.
-- Layer TEMPLATE (required for GetFeatureInfo requests)
+- Layer TEMPLATE (required for GetFeatureInfo requests - see :ref:`template`)
 - Layer DUMP TRUE (only required for GetFeatureInfo GML requests)
 Let's go through each of these parameters in more detail:
@@ -309,18 +311,22 @@
 - **Configuring for GetFeatureInfo Requests:**
-  You must set the layer TEMPLATE parameter for the layer to be queryable by
-  GetFeatureInfo requests.  For requests of type "text/html" you should also set
-  the layer HEADER and FOOTER parameters.
+  You must set the layer TEMPLATE parameter for the layer to be
+  queryable by GetFeatureInfo requests (see :ref:`template`).  For
+  requests of type "text/html" you should also set the layer HEADER
+  and FOOTER parameters.
-  For GetFeatureInfo requests of GML you must set the layer to DUMP TRUE in the
-  mapfile.  As of MapServer 4.6 you must also set the *gml_\** metadata for the
-  layer attributes to be served (see the Layer Object metadata in the Reference
-  Section later in this document).
+  For GetFeatureInfo requests of GML you must set the layer to DUMP
+  TRUE in the mapfile.  As of MapServer 4.6 you must set the *gml_\**
+  metadata for the layer attributes to be served (see the Layer Object
+  metadata in the Reference Section later in this document).  To
+  include geometry, gml_geometries and gml_[name]_type has to be
+  specified.
-  Here are working examples of GetFeatureInfo requests: `text/plain`_ / `text/html`_
-  / `gml`_ (for gml, your browser might ask you to save the file, if so save it
-  locally as a .gml file and view it in a text editor)
+  Here are working examples of GetFeatureInfo requests: `text/plain`_
+  / `text/html`_ / `gml`_ (for gml, your browser might ask you to save
+  the file, if so save it locally as a .gml file and view it in a text
+  editor)
 Test Your WMS Server
@@ -967,12 +973,13 @@
   - Used to specify an additional MIME type that can be used when responding
     to the GetFeature request.
-    For example if you want to use the layer's HTML template as a base for its
-    response, you need to add "WMS_FEATURE_INFO_MIME_TYPE" "text/html".
-    Setting this will have the effect of advertizing text/html as one of the
-    MIME types supported for a GetFeature request. You also need to make sure
-    that the layer points to a valid html template. The client can then call
-    the server with INFO_FORMAT=text/html.
+    For example if you want to use the layer's HTML template as a base
+    for its response, you need to add "WMS_FEATURE_INFO_MIME_TYPE"
+    "text/html".  Setting this will have the effect of advertizing
+    text/html as one of the MIME types supported for a GetFeature
+    request. You also need to make sure that the layer points to a
+    valid html template (see :ref:`template`).  The client can then
+    call the server with INFO_FORMAT=text/html.
   - If not specified, MapServer by default has text/plain and GML implemented.
   - Note that for GML to be returned the layer in the wms-server mapfile must
Modified: trunk/docs/en/ogc/wms_server.txt
--- trunk/docs/en/ogc/wms_server.txt	2011-09-28 21:27:18 UTC (rev 12596)
+++ trunk/docs/en/ogc/wms_server.txt	2011-09-28 22:36:48 UTC (rev 12597)
@@ -68,9 +68,11 @@
@@ -169,7 +171,7 @@
+  specified.
+  editor)
