[mapserver-commits] r12999 - trunk/docs/en/mapcache
Wed Jan 18 13:40:33 EST 2012
Author: jmckenna
Date: 2012-01-18 10:40:32 -0800 (Wed, 18 Jan 2012)
New Revision: 12999
   trunk/docs/en/mapcache/install.txt
more windows config notes
Modified: trunk/docs/en/mapcache/install.txt
--- trunk/docs/en/mapcache/install.txt	2012-01-18 18:32:07 UTC (rev 12998)
+++ trunk/docs/en/mapcache/install.txt	2012-01-18 18:40:32 UTC (rev 12999)
@@ -525,6 +525,17 @@
 - Configure your *mapcache.xml* file (see the :ref:`Configuration <mapcache_config>` section
   for help)
+.. warning::
+    If you receive an error such as "cache disk: host system does not support file symbolic linking"
+    you should comment the line "<symlink_blank/>" in your mapcache.xml file, such as:
+    .. code-block:: bash
+       <cache name="disk" type="disk">
+         <base>D:/ms4w/tmp/ms_tmp/cache</base>
+         <!--<symlink_blank/>-->
+       </cache>
 - Finally, restart your Apache.  You should see a message in Apache's error.log with a message
   similar to:
