[mapserver-commits] r13209 - sandbox/tb-labels
Wed Mar 7 12:23:57 EST 2012
Author: tbonfort
Date: 2012-03-07 09:23:56 -0800 (Wed, 07 Mar 2012)
New Revision: 13209
   sandbox/tb-labels/mapdraw.c
   sandbox/tb-labels/mapfile.c
   sandbox/tb-labels/maplabel.c
avoid some premature allocations on labelObj->poly
Modified: sandbox/tb-labels/mapdraw.c
--- sandbox/tb-labels/mapdraw.c	2012-03-07 11:52:51 UTC (rev 13208)
+++ sandbox/tb-labels/mapdraw.c	2012-03-07 17:23:56 UTC (rev 13209)
@@ -2792,17 +2792,36 @@
             label_buffer = (labelPtr->buffer*image->resolutionfactor);
             label_mindistance = (labelPtr->mindistance*image->resolutionfactor);
-            /* copy the bounds into the cache's polygon */
-            msCopyShape(&(cachePtr->labelpath->bounds), cachePtr->poly);
             /* compare against image bounds, rendered labels and markers (sets cachePtr->status), if FORCE=TRUE then skip it */
             cachePtr->status = MS_TRUE;
+            assert(cachePtr->poly == NULL);
+            /* use a ref to the bounds as the cache's polygon */
+            cachePtr->poly = &cachePtr->labelpath->bounds;
             if(!labelPtr->force)
               cachePtr->status = msTestLabelCacheCollisions(map,cachePtr,label_mindistance,priority,l);
-            msFreeShape(&(cachePtr->labelpath->bounds));
-            if(!cachePtr->status)
-              continue;
+            if(!cachePtr->status) {
+               cachePtr->poly = NULL;
+               msFreeShape(&cachePtr->labelpath->bounds);
+               continue;
+            } else {
+               /* take ownership of cachePtr->poly*/
+               cachePtr->poly = (shapeObj*)msSmallMalloc(sizeof(shapeObj));
+               msInitShape(cachePtr->poly);
+               cachePtr->poly->type = MS_SHAPE_POLYGON;
+               cachePtr->poly->numlines = cachePtr->labelpath->bounds.numlines;
+               cachePtr->poly->line = cachePtr->labelpath->bounds.line;
+               cachePtr->labelpath->bounds.numlines = 0;
+               cachePtr->labelpath->bounds.line = NULL;
+               cachePtr->poly->bounds.minx = cachePtr->labelpath->bounds.bounds.minx;
+               cachePtr->poly->bounds.miny = cachePtr->labelpath->bounds.bounds.miny;
+               cachePtr->poly->bounds.maxx = cachePtr->labelpath->bounds.bounds.maxx;
+               cachePtr->poly->bounds.maxy = cachePtr->labelpath->bounds.bounds.maxy;
             msDrawTextLine(image, labelPtr->annotext, labelPtr, cachePtr->labelpath, &(map->fontset), layerPtr->scalefactor); /* Draw the curved label */
@@ -2967,7 +2986,7 @@
                   if(labelPtr->force == MS_OFF) {
                      /* check for collisions inside the label group */
-                     if(cachePtr->poly->numlines && intersectLabelPolygons(&metrics_poly, cachePtr->poly) == MS_TRUE) {
+                     if(cachePtr->poly && cachePtr->poly->numlines && intersectLabelPolygons(&metrics_poly, cachePtr->poly) == MS_TRUE) {
                         /* there was a self intersection */
                         continue; /* next position, labelPtr->status is left to MS_OFF */
@@ -3019,7 +3038,7 @@
                    } else {
                         /* check for collisions inside the label group unless the label is FORCE GROUP */
                            break; /* collision within the group */
@@ -3041,6 +3060,10 @@
                 case we still want to compute the full cachePtr->poly to be used for offset tests */
                 labelPtr->status = MS_OFF;
               } else {
+                 if(!cachePtr->poly) {
                  if(labelPtr->annotext) {
                     msAddLine(cachePtr->poly, metrics_poly.line);
@@ -3052,11 +3075,6 @@
             } /* next label in the group */
-            /* add the marker polygon if we have one */
-            if(marker_poly.numlines) {
-               msAddLine(cachePtr->poly, marker_poly.line);
-            msComputeBounds(cachePtr->poly);
              * cachePtr->status can be set to ON only if all it's labels didn't collide
@@ -3068,8 +3086,22 @@
                   break;
+            if(cachePtr->status == MS_ON || classPtr->leader.maxdistance) {
+               /* add the marker polygon if we have one */
+               if(marker_poly.numlines) {
+                  msAddLine(cachePtr->poly, marker_poly.line);
+               if(cachePtr->poly)
+                  msComputeBounds(cachePtr->poly);
             if(cachePtr->status == MS_OFF)
                continue; /* next label, as we had a collision */
             if(layerPtr->type == MS_LAYER_ANNOTATION && cachePtr->numstyles > 0) { /* need to draw a marker */
               for(i=0; i<cachePtr->numstyles; i++)
Modified: sandbox/tb-labels/mapfile.c
--- sandbox/tb-labels/mapfile.c	2012-03-07 11:52:51 UTC (rev 13208)
+++ sandbox/tb-labels/mapfile.c	2012-03-07 17:23:56 UTC (rev 13209)
@@ -5441,8 +5441,10 @@
       for(j=0;j<cacheslot->labels[i].numlabels; j++) freeLabel(&(cacheslot->labels[i].labels[j]));
       msFree(cacheslot->labels[i].labels);
-      msFreeShape(cacheslot->labels[i].poly); /* empties the shape */
-      msFree(cacheslot->labels[i].poly); /* free's the pointer */
+      if(cacheslot->labels[i].poly) {
+         msFreeShape(cacheslot->labels[i].poly); /* empties the shape */
+         msFree(cacheslot->labels[i].poly); /* free's the pointer */
       for(j=0;j<cacheslot->labels[i].numstyles; j++) freeStyle(&(cacheslot->labels[i].styles[j]));
       msFree(cacheslot->labels[i].styles);
Modified: sandbox/tb-labels/maplabel.c
--- sandbox/tb-labels/maplabel.c	2012-03-07 11:52:51 UTC (rev 13208)
+++ sandbox/tb-labels/maplabel.c	2012-03-07 17:23:56 UTC (rev 13209)
@@ -405,8 +405,9 @@
   cachePtr->featuresize = featuresize;
-  cachePtr->poly = (shapeObj *) msSmallMalloc(sizeof(shapeObj));
-  msInitShape(cachePtr->poly);
+  //cachePtr->poly = (shapeObj *) msSmallMalloc(sizeof(shapeObj));
+  //msInitShape(cachePtr->poly);
   cachePtr->status = MS_FALSE;
@@ -580,12 +581,13 @@
-  if(layerPtr->type == MS_LAYER_POINT) { /* cache the marker placement, it's already on the map */
+  if(layerPtr->type == MS_LAYER_POINT && classPtr->numstyles > 0) { /* cache the marker placement, it's already on the map */
     rectObj rect;
     double w, h;
@@ -673,7 +675,7 @@
       int current_priority, int current_label) {
    labelCacheObj *labelcache = &(map->labelcache);
   int i, p, ll, pp;
-  double label_width;
+  double label_width = 0;
   labelCacheMemberObj *curCachePtr=NULL;
