[mapserver-commits] r13211 - branches/branch-6-0/docs/en/mapfile trunk/docs/en/mapfile
Wed Mar 7 19:03:14 EST 2012
Author: havatv
Date: 2012-03-07 16:03:14 -0800 (Wed, 07 Mar 2012)
New Revision: 13211
   branches/branch-6-0/docs/en/mapfile/expressions.txt
   trunk/docs/en/mapfile/expressions.txt
Updated the expressions document on character encoding (#3090).
Modified: branches/branch-6-0/docs/en/mapfile/expressions.txt
--- branches/branch-6-0/docs/en/mapfile/expressions.txt	2012-03-07 20:08:42 UTC (rev 13210)
+++ branches/branch-6-0/docs/en/mapfile/expressions.txt	2012-03-08 00:03:14 UTC (rev 13211)
@@ -134,7 +134,20 @@
   component in the pixel value, respectively.
+.. index::
+   single: Character encoding
+Character encoding
+With Mapserver there is no way to specify the character encoding of
+the mapfile or the layer data sources, so Mapserver can't do the
+character encoding translation.
+If the character encoding of the data source is not the same as the
+character encoding of the map file, they could be converted to a
+common encoding.
 .. index::
    single: Expression types
Modified: trunk/docs/en/mapfile/expressions.txt
--- trunk/docs/en/mapfile/expressions.txt	2012-03-07 20:08:42 UTC (rev 13210)
+++ trunk/docs/en/mapfile/expressions.txt	2012-03-08 00:03:14 UTC (rev 13211)
+.. index::
+Character encoding
+common encoding.
 .. index::
