[mapserver-commits] r13249 - trunk/mapserver
Wed Mar 14 09:20:48 EDT 2012
Author: tbonfort
Date: 2012-03-14 06:20:48 -0700 (Wed, 14 Mar 2012)
New Revision: 13249
   trunk/mapserver/mapuvraster.c
USE_GDAL preprocessor define on whole file
Modified: trunk/mapserver/mapuvraster.c
--- trunk/mapserver/mapuvraster.c	2012-03-14 11:38:52 UTC (rev 13248)
+++ trunk/mapserver/mapuvraster.c	2012-03-14 13:20:48 UTC (rev 13249)
@@ -27,10 +27,12 @@
  * DEALINGS IN THE SOFTWARE.
+#include "mapserver.h"
+#ifdef USE_GDAL
 #include <assert.h>
 #include <math.h>
 #include "mapresample.h"
-#include "mapserver.h"
 #include "mapthread.h"
 #define MSUVRASTER_NUMITEMS        6
@@ -88,7 +90,6 @@
 static int msUVRASTERLayerInitItemInfo(layerObj *layer)
-#ifdef USE_GDAL
   uvRasterLayerInfo *uvlinfo = (uvRasterLayerInfo *) layer->layerinfo;
   int   i;
   int *itemindexes;
@@ -141,27 +142,14 @@
   return(MS_SUCCESS);
-#else
-  msSetError(MS_MISCERR, "GDAL support is not available.",
-             "msUVRASTERLayerInitItemInfo()");
-#endif
 void msUVRASTERLayerFreeItemInfo(layerObj *layer)
-#ifdef USE_GDAL
   if (layer->iteminfo)
       free(layer->iteminfo);
   layer->iteminfo = NULL;
-#else
-             "msUVRASTERLayerFreeItemInfo()");
-#endif
 static void msUVRasterLayerInfoInitialize(layerObj *layer)
@@ -228,12 +216,6 @@
 int msUVRASTERLayerOpen(layerObj *layer)
-#ifndef USE_GDAL
-    msSetError( MS_IMGERR,
-                "UV Rasters queries only supported with GDAL support enabled.",
-                "msUVRASTERLayerOpen()" );
-    return MS_FAILURE;
-#else
     uvRasterLayerInfo *uvlinfo;
     /* If we don't have info, initialize an empty one now */
@@ -245,29 +227,18 @@
     uvlinfo->refcount = uvlinfo->refcount + 1;
     return MS_SUCCESS;
-#endif /* def USE_GDAL */
 int msUVRASTERLayerIsOpen(layerObj *layer)
-#ifndef USE_GDAL
-                "msRasterLayerIsOpen()" );
-    return MS_FALSE;
-#else
     if (layer->layerinfo)
         return MS_TRUE;
     return MS_FALSE;
-#endif
 int msUVRASTERLayerClose(layerObj *layer)
-#ifndef USE_GDAL
-#else
     if( uvlinfo != NULL )
@@ -278,12 +249,10 @@
             msUVRasterLayerInfoFree( layer );
     return MS_SUCCESS;
 int msUVRASTERLayerGetItems(layerObj *layer)
-#ifdef USE_GDAL
   if( uvlinfo == NULL )
@@ -301,13 +270,6 @@
   layer->items[layer->numitems] = NULL;
   return msUVRASTERLayerInitItemInfo(layer);
-#else
-             "msGDALLayerGetItems()");
-  return(MS_FAILURE);
-#endif
@@ -323,9 +285,6 @@
   char tmp[100];
   float size_scale;
   int *itemindexes = (int*)layer->iteminfo;
-#ifndef USE_GDAL
-    return NULL;
-#else
   if(layer->numitems == 0)
       return(NULL);
@@ -391,15 +350,11 @@
   return values;
-#endif
 int msUVRASTERLayerWhichShapes(layerObj *layer, rectObj rect, int isQuery)
-#ifndef USE_GDAL
-#else
     imageObj *image_tmp;
     mapObj   map_tmp;
@@ -565,14 +520,10 @@
     uvlinfo->next_shape = 0;
     return MS_SUCCESS;
 int msUVRASTERLayerGetShape(layerObj *layer, shapeObj *shape, resultObj *record)
-#ifndef USE_GDAL
-#else
     lineObj line ;
     pointObj point;
@@ -625,14 +576,10 @@
     return MS_SUCCESS;
 int msUVRASTERLayerNextShape(layerObj *layer, shapeObj *shape)
-#ifndef USE_GDAL
-#else
     if( uvlinfo->next_shape < 0
@@ -651,7 +598,6 @@
       return msUVRASTERLayerGetShape( layer, shape, &record);
@@ -662,9 +608,6 @@
 int msUVRASTERLayerGetExtent(layerObj *layer, rectObj *extent)
-#ifndef USE_GDAL
-#else
   char szPath[MS_MAXPATHLEN];
   mapObj *map = layer->map;
   double adfGeoTransform[6];
@@ -751,7 +694,6 @@
   extent->miny = adfGeoTransform[3] + nYSize * adfGeoTransform[5];
   return MS_SUCCESS;
@@ -838,3 +780,10 @@
     return MS_SUCCESS;
+#else
+int msUVRASTERLayerInitializeVirtualTable(layerObj *layer) {
+   msSetError(MS_MISCERR, "UVRaster Layer needs GDAL support, but it it not compiled in", "msUVRASTERLayerInitializeVirtualTable()");
+   return MS_FAILURE;
+#endif
