[mapserver-commits] [mapserver/mapserver] 7f3ceb: PostGIS backend: translate insensitive equality co...
Even Rouault noreply at github.com
Fri Dec 13 06:58:14 PST 2019
  Branch: refs/heads/master
  Home:   https://github.com/mapserver/mapserver
  Commit: 7f3cebc613f06ebab435e377e4a22f5eccf9d63e
      https://github.com/mapserver/mapserver/commit/7f3cebc613f06ebab435e377e4a22f5eccf9d63e
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2019-11-22 (Fri, 22 Nov 2019)
  Changed paths:
    M mappostgis.c
  Log Message:
  PostGIS backend: translate insensitive equality comparison as Postgre SQL lower(foo::text) = lower('bar').
Fixes a performance issue dating from 7.0
The wfs_filter_postgis.map wfs_filter_postgis_property_is_equal_case_insensitive
test case exercices this code path.
  Commit: a5318701cf7c2c14b75d4f6595ee7bd3a4b703fd
      https://github.com/mapserver/mapserver/commit/a5318701cf7c2c14b75d4f6595ee7bd3a4b703fd
  Date:   2019-12-13 (Fri, 13 Dec 2019)
  Changed paths:
    M mappostgis.c
  Log Message:
  Merge pull request #5949 from rouault/postgis_implement_ieq
PostGIS backend: translate insensitive equality comparison as PostgreSQL lower(foo::text) = lower('bar').
Compare: https://github.com/mapserver/mapserver/compare/b64932c70056...a5318701cf7c
