[mapserver-commits] [mapserver/mapserver] e0559b: PostGIS backend: translate insensitive equality co...
Even Rouault noreply at github.com
Fri Dec 13 07:07:13 PST 2019
  Branch: refs/heads/branch-7-4
  Home:   https://github.com/mapserver/mapserver
  Commit: e0559baf8ccaf2532e5d47fa8a740f55ae1d531e
      https://github.com/mapserver/mapserver/commit/e0559baf8ccaf2532e5d47fa8a740f55ae1d531e
  Author: Even Rouault <even.rouault at spatialys.com>
  Date:   2019-12-13 (Fri, 13 Dec 2019)
  Changed paths:
    M mappostgis.c
  Log Message:
  PostGIS backend: translate insensitive equality comparison as Postgre SQL lower(foo::text) = lower('bar').
Fixes a performance issue dating from 7.0
The wfs_filter_postgis.map wfs_filter_postgis_property_is_equal_case_insensitive
test case exercices this code path.
  Commit: 0e2b1b3a43f7b474f806b71eb0e132beb09dce2e
      https://github.com/mapserver/mapserver/commit/0e2b1b3a43f7b474f806b71eb0e132beb09dce2e
  Changed paths:
    M mappostgis.c
  Log Message:
  Merge pull request #5950 from rouault/backport_5949_to_branch_7_4
[Backport 7.4] PostGIS backend: translate insensitive equality comparison as PostgreSQL lower(foo::text) = lower('bar').
Compare: https://github.com/mapserver/mapserver/compare/208d3d94d81d...0e2b1b3a43f7
