[Mapserver-dev] Yanking GD 1 and Freetype 1 supportfromCVS version...
Daniel Morissette morissette at dmsolutions.ca
Sat Apr 26 13:44:21 EDT 2003
Steve Lime wrote:
> I used the former, works fine. I still need to tweak the configure
> script a bit. There
> are a few funky things in the GD section like a do loop to process /usr
> and /usr/local.
> That doesn't seem necessary but I'm no configure expert.
All that GD stuff was rewritten by Tom P. a year or two ago, hopefully
Tom is still around and could answer questions you may have.
> I'm not sure
> the script
> is right when a user sets an lib directory either, need to read up on
> AC_CHECK_LIB()
> in those cases. It works ok though in most circumstances. Commited on
> Wed.
FYI I committed a fix to the AC_CHECK_LIB() call (added -L$GD_LIBDIR)
for the case where an explicit path is provided for GD.
 DM Solutions Group              http://www.dmsolutions.ca/
