[Mapserver-dev] QUERY_STRING command line parameter
Daniel Morissette dmorissette at dmsolutions.ca
Mon Aug 2 09:17:32 EDT 2004
Frank Rittinger wrote:
> the current windows binaries (4.2.0) from the mapserver website don't support
> the QUERY_STRING command line parameter anymore.  I couldn't find any comment
> on this in the changelog either.
> Is this the intended behaviour for the new mapserver versions or just a
> configuration option?
There was definitely no intention to disable the QUERY_STRING
command-line parameter. I can't test on Windows, but it still works for
me with 4.2.2 on Linux. How did you test that? Did you put double quotes
around the "QUERY_STRING=..." value?
  DM Solutions Group              http://www.dmsolutions.ca/
