[Mapserver-dev] QUERY_STRING command line parameter
Frank Rittinger gis at schnegg.net
Mon Aug 2 10:12:02 EDT 2004
Hello Daniel,
On Monday 02 August 2004 15:17, Daniel Morissette wrote:
> There was definitely no intention to disable the QUERY_STRING
> command-line parameter. I can't test on Windows, but it still works for
> me with 4.2.2 on Linux. How did you test that? Did you put double quotes
> around the "QUERY_STRING=..." value?
Until now, I was useing mapserver 4.0 in the form:
mapserv QUERY_STRING="map=foo.map"
With mapserver 4.2.0 (that's the one on the mapserver website) I get the
message that mapserver can only be used as a CGI script.  Putting quotes
around the QUERY_STRING parameter doesn't change the error.
Regards,	 Frank
