[Mapserver-dev] QUERY_STRING command line parameter
Daniel Morissette dmorissette at dmsolutions.ca
Mon Aug 2 11:04:44 EDT 2004
Frank Rittinger wrote:
> Hello Daniel,
> On Monday 02 August 2004 15:17, Daniel Morissette wrote:
>>There was definitely no intention to disable the QUERY_STRING
>>command-line parameter. I can't test on Windows, but it still works for
>>me with 4.2.2 on Linux. How did you test that? Did you put double quotes
>>around the "QUERY_STRING=..." value?
> Until now, I was useing mapserver 4.0 in the form:
> mapserv QUERY_STRING="map=foo.map"
> With mapserver 4.2.0 (that's the one on the mapserver website) I get the
> message that mapserver can only be used as a CGI script.  Putting quotes
> around the QUERY_STRING parameter doesn't change the error.
Can you please try with the 4.2.1 binary on the maptools.org site and if
it has the same problem then please file a bug:
http://maptools.org/php_mapscript/index.phtml?page=downloads.html
  DM Solutions Group              http://www.dmsolutions.ca/
