[Mapserver-dev] Label/Classes Items
Fernando S. simon at inf.univali.br
Thu May 6 08:15:43 EDT 2004
This is a multi-part message in MIME format.
--------------060101080300010501050402
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
    Sorry to post here, but I posted in users list, but I don't have any
feedback.
    I am with some problems with label items. I have one layer with two
classes and I don't have data because I NEED to use FEATURE.
    Well, I'm using mapscript to set and add the feature, this items are
draw correctly, they appear in the map. They are drawed using first
class definitions.
    Now I need to set correctly the class using mapscript. I tried to
set the classindex in "ms_newShapeObj", the same that I use in
"addFeature". I set this value before I execute "addFeature". But the
data always drawed by first class. When I execute an echo before set the
classindex was show 0 and after I changed, was show the value that I
set, but always the feature it's drawed by first class. I changed the
values to many options (1, 2, 3....) but without effect.
    I can't to define one EXPRESSION in class because I don't have
anything to define. The feature (shapeObj) only support to change two
attributes "text" and "classindex". Text to label and index to class,
correct?
    I used this layer:
layer
    name 'test'
    type point
    status off
    labelcache on
    class
        symbol 'coleta'
        color 255 0 0
        outlinecolor 255 255 255
        size 10
        label
            antialias on
            color 255 255 255
            outlinecolor 0 0 0
            buffer 2
            font verdana
            type truetype
            force false
            size 8
            position ll
        end
    end
    class
        color 0 0 0
        symbol 'sede'
        size 10
        label
            antialias on
            color 125 255 155
            outlinecolor 125 0 123
            buffer 2
            font verdana
            type truetype
            force true
            size 8
            position cc
        end
    end
end
    I changed many values in this layer, labelcache, force,
position...... but always the same efect. First class.
    And I use this mapscript code:
        if ($layer_name == 'test')
            ociConectar();  //Connect to database
            ociExecutar( $pesq_faz_suinos);  //Execute the query
            $p = ms_newpointObj();
            while (list($cd_fornecedor, $x, $y ) = ociTupla())
                    $p->setXY($x, $y);
                    if ($circle->contains($p))
                          isset($ShapePonto);
                          isset($Ponto);
                          $Ponto = ms_newLineObj();
                          $Ponto->addXY( $x, $y );
                          $ShapePonto = ms_newShapeObj( MS_SHAPE_POINT );
                          $ShapePonto->add( $Ponto );
                          echo $ShapePonto->classindex; //Show 0
                          echo $layer->numclasses; //Show 2
                          $ShapePonto->set('classindex',1);
                          echo $ShapePonto->classindex; //Show 1
                          $ShapePonto->set('text',$cd_fornecedor);
                          $layer->addFeature( $ShapePonto );
                           $Ponto->free();
                           $ShapePonto->free();
                           unset($Ponto);
                           unset($ShapePonto);
    Now, how can I do to set the indexclass correctly?How I can change
between the classes using Mapscript?
    I'm using version 4.02.
    Sorry my poor english.
    Thank's for help.
Fernando Simon
DataBase Manager, Mapserver, OracleSpatial and PostGis Developer
G10 - Laboratório de Computação Aplicada
MapOracleSpatial developer
http://g10.cttmar.univali.br
Content-Type: text/html; charset=us-ascii
Content-Transfer-Encoding: 7bit
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
  <meta content="text/html;charset=ISO-8859-1" http-equiv="Content-Type">
  <title></title>
</head>
<body bgcolor="#ffffff" text="#000000">
<title></title>
Hi,<br>
&nbsp;&nbsp;&nbsp; Sorry to post here, but I posted in users list, but I don't have
any feedback.<br>
&nbsp;&nbsp;&nbsp; I am with some problems with label items. I have one layer with two
classes and I don't have data because I NEED to use FEATURE. <br>
&nbsp;&nbsp;&nbsp; Well, I'm using mapscript to set and add the feature, this items
are draw correctly, they appear in the map. They are drawed using first
class definitions. <br>
&nbsp;&nbsp;&nbsp; Now I need to set correctly the class using mapscript. I tried to
the classindex was show 0 and after I changed, was show the value that
I set, but always the feature it's drawed by first class. I changed the
values to many options (1, 2, 3....) but without effect.<br>
&nbsp;&nbsp;&nbsp; I can't to define one EXPRESSION in class because I don't have
correct?<br>
<br>
&nbsp;&nbsp;&nbsp; I used this layer:<br>
<br>
layer<br>
&nbsp;&nbsp;&nbsp; name 'test'<br>
&nbsp;&nbsp;&nbsp; type point<br>
&nbsp;&nbsp;&nbsp; status off<br>
&nbsp;&nbsp;&nbsp; labelcache on<br>
&nbsp;&nbsp;&nbsp; class<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;symbol 'coleta'<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;color 255 0 0<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;outlinecolor 255 255 255<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;size 10<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; label<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; antialias on&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; color 255 255 255<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; outlinecolor 0 0 0<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; buffer 2<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; font verdana<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; type truetype<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; force false<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; size 8<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; position ll<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; end&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;<br>
&nbsp;&nbsp;&nbsp; end<br>
&nbsp;&nbsp;&nbsp; class&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;color 0 0 0<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;symbol 'sede'<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; antialias on<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; color 125 255 155<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; outlinecolor 125 0 123<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; force true<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp; position cc<br>
end&nbsp;&nbsp; <br>
<br>
&nbsp;&nbsp;&nbsp; I changed many values in this layer, labelcache, force,
position...... but always the same efect. First class.<br>
<br>
&nbsp;&nbsp;&nbsp; And I use this mapscript code:<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if ($layer_name == 'test')<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; ociConectar();&nbsp; //Connect to database<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; ociExecutar( $pesq_faz_suinos);&nbsp; //Execute the query<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $p = ms_newpointObj();<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp; while (list($cd_fornecedor, $x, $y ) = ociTupla()) <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $p-&gt;setXY($x, $y);&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; if ($circle-&gt;contains($p))<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; {<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;&nbsp;&nbsp; isset($ShapePonto);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; isset($Ponto);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $Ponto = ms_newLineObj();<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $Ponto-&gt;addXY( $x, $y );<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $ShapePonto = ms_newShapeObj( MS_SHAPE_POINT
);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $ShapePonto-&gt;add( $Ponto );<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; echo $ShapePonto-&gt;classindex; //Show 0<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; echo $layer-&gt;numclasses; //Show 2<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $ShapePonto-&gt;set('classindex',1); <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; echo $ShapePonto-&gt;classindex; //Show 1<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $ShapePonto-&gt;set('text',$cd_fornecedor);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; $layer-&gt;addFeature( $ShapePonto );<br>
&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; $Ponto-&gt;free();<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; $ShapePonto-&gt;free();&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp;
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; unset($Ponto);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; unset($ShapePonto);<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp; <br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; }<br>
<br>
&nbsp;&nbsp;&nbsp; Now, how can I do to set the indexclass correctly?How I can change
between the classes using Mapscript?<br>
&nbsp;&nbsp;&nbsp; I'm using version 4.02.<br>
<br>
&nbsp;&nbsp;&nbsp; Sorry my poor english.<br>
&nbsp;&nbsp;&nbsp; Thank's for help.<br>
<br>
<font face="Arial" size="2"><span
 style="font-size: 10pt; font-family: Arial;">==================================================================
<br>
Fernando Simon<br>
DataBase Manager, Mapserver, OracleSpatial and PostGis Developer <br>
G10 - Laborat&oacute;rio de Computa&ccedil;&atilde;o Aplicada<br>
MapOracleSpatial developer <br>
<a href="http://g10.cttmar.univali.br">http://g10.cttmar.univali.br</a>
<br>
==================================================================</span></font><br>
</body>
</html>
--------------060101080300010501050402--
