[Mapserver-dev] RE: [UMN_MAPSERVER-USERS] Oracle Spatial Performance
Smith, Michael ERDC-CRREL-NH Michael.Smith at erdc.usace.army.mil
Sun Sep 26 14:38:55 EDT 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C4A3F7.F6FEF972
Content-Type: text/plain;
	charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I don't see one, and we have recommended this change before I believe.=20
Mike Smith
-----Original Message-----
To: Smith, Michael ERDC-CRREL-NH
Cc: mapserver-dev at lists.gis.umn.edu
Sent: 9/26/2004 10:45 AM
Subject: Re: [UMN_MAPSERVER-USERS] Oracle Spatial Performance
Any reason not to simply apply this change to the standard source?
On Sunday, September 26, 2004, at 05:47 AM, Smith, Michael =20
ERDC-CRREL-NH wrote:
> It is also very important for performance reasons to increase the =20
> array size in maporaclespatial.c and recompile. We generally =
recommend
> setting array size to ~ 1000. We generally see an order of magnitude  =
> increase in speed with this change.
> Mike Smith
> USACE-CRREL
> Remote Sensing GIS Center of Expertise
> Hanover, NH
> From: Frank Warmerdam
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Sent: 9/25/2004 7:34 PM
> Vladimir Guzm=E1n wrote:
> > Hello, List.
> > I don't know if this is an off-topic question but, I really need
some
> help.
> > I've worked a lot with mapserver, specially with phpmapscript, and
> with
> > shape files and postgis data.
> > Finally, about 6 months ago, we received a request from a customer
in
> > order to develop a web application that would be able to connect
with
> > oracle data.
> > Well, after face all kinds of issues with oracle spatial, =
everything
> is
> > working fine now.=A0 Except the speed.
> > Every map request to oracle spatial takes at least 20 seconds, with
> very
> > small geometries, and in some cases it takes 2 minutes or more.
> > I would like you to give me some clue, because I've worked with
> postgis
> > and shps and I've never had this kind of problems.
> > All the geometries are indexed.
> > The time responses are almost the same working with ORACLESPATIAL
and
> > OGR connection.
> > For example:
> > The command:
> > ogrinfo OCI:xxx/xxx at xxx -sql "SELECT ID, ORA_GEOMETRY, NOMBRE FROM
> > SIG_DEPTOS"
> > Takes 1 minute.
> > The same geometry in shp:
> > ogrinfo -al departamentos.shp
> > Takes less than one second.
> Vladimir,
> I can think of a couple of issues.
> First, the connection overhead to Oracle tends to be pretty =
expensive.
> In my work it was several seconds to a local Oracle instance.=A0 When
> using
> MapServer in "cgi" mode where a new process is forked and needs to
> connect
> to Oracle for each map request the extra overhead can be quite
> devestating.
> The presume solution to this is to keep the process resident, for
> instance
> by using FastCGI and caching the oracle connection.=A0 This is =
currently
> not supported by MapServer, but I am working on FastCGI support again
> on
> behalf of Refractions and so a solution may become available in the
> coming
> months.
> Second, by default OGR will collect schema information from all the
> tables (or at least spatial tables) in your database. This can be =
very
> expensive for a database with alot of tables.=A0 However, this issue =
is
> unique to OGR connections to Oracle, and should not occur with the
more
> direct Oracle support in MapServer.
> Best regards,
> ---------------------------------------=20
> I set the clouds in motion - turn up=A0=A0 | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush=A0=A0=A0 | Geospatial Programmer =
for
Rent
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Diso-8859-1">
<META NAME=3D"Generator" CONTENT=3D"MS Exchange Server version =
5.5.2655.35">
<TITLE>RE: [UMN_MAPSERVER-USERS] Oracle Spatial Performance</TITLE>
</HEAD>
<BODY>
<P><FONT SIZE=3D2>I don't see one, and we have recommended this change =
before I believe. </FONT>
</P>
<P><FONT SIZE=3D2>Mike Smith</FONT>
</P>
<P><FONT SIZE=3D2>-----Original Message-----</FONT>
<BR><FONT SIZE=3D2>From: Paul Ramsey</FONT>
<BR><FONT SIZE=3D2>To: Smith, Michael ERDC-CRREL-NH</FONT>
<BR><FONT SIZE=3D2>Cc: mapserver-dev at lists.gis.umn.edu</FONT>
<BR><FONT SIZE=3D2>Sent: 9/26/2004 10:45 AM</FONT>
<BR><FONT SIZE=3D2>Subject: Re: [UMN_MAPSERVER-USERS] Oracle Spatial =
Performance</FONT>
</P>
<P><FONT SIZE=3D2>Any reason not to simply apply this change to the =
standard source?</FONT>
</P>
<P><FONT SIZE=3D2>On Sunday, September 26, 2004, at 05:47 AM, Smith, =
Michael&nbsp; </FONT>
<BR><FONT SIZE=3D2>ERDC-CRREL-NH wrote:</FONT>
</P>
<P><FONT SIZE=3D2>&gt; It is also very important for performance =
reasons to increase the&nbsp; </FONT>
<BR><FONT SIZE=3D2>&gt; array size in maporaclespatial.c and recompile. =
We generally recommend</FONT>
</P>
<P><FONT SIZE=3D2>&gt; setting array size to ~ 1000. We generally see =
an order of magnitude&nbsp; </FONT>
<BR><FONT SIZE=3D2>&gt; increase in speed with this change.</FONT>
<BR><FONT SIZE=3D2>&gt;</FONT>
<BR><FONT SIZE=3D2>&gt; Mike Smith</FONT>
<BR><FONT SIZE=3D2>&gt; USACE-CRREL</FONT>
<BR><FONT SIZE=3D2>&gt; Remote Sensing GIS Center of Expertise</FONT>
<BR><FONT SIZE=3D2>&gt; Hanover, NH</FONT>
<BR><FONT SIZE=3D2>&gt; -----Original Message-----</FONT>
<BR><FONT SIZE=3D2>&gt; From: Frank Warmerdam</FONT>
<BR><FONT SIZE=3D2>&gt; To: MAPSERVER-USERS at LISTS.UMN.EDU</FONT>
<BR><FONT SIZE=3D2>&gt; Sent: 9/25/2004 7:34 PM</FONT>
<BR><FONT SIZE=3D2>&gt; Subject: Re: [UMN_MAPSERVER-USERS] Oracle =
Spatial Performance</FONT>
<BR><FONT SIZE=3D2>&gt; Vladimir Guzm=E1n wrote:</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Hello, List.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt;</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; I don't know if this is an off-topic =
question but, I really need</FONT>
<BR><FONT SIZE=3D2>some</FONT>
<BR><FONT SIZE=3D2>&gt; help.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; I've worked a lot with mapserver, =
specially with phpmapscript, and</FONT>
<BR><FONT SIZE=3D2>&gt; with</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; shape files and postgis data.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Finally, about 6 months ago, we received a =
request from a customer</FONT>
<BR><FONT SIZE=3D2>in</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; order to develop a web application that =
would be able to connect</FONT>
<BR><FONT SIZE=3D2>with</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; oracle data.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Well, after face all kinds of issues with =
oracle spatial, everything</FONT>
<BR><FONT SIZE=3D2>&gt; is</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; working fine now.=A0 Except the =
speed.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Every map request to oracle spatial takes =
at least 20 seconds, with</FONT>
<BR><FONT SIZE=3D2>&gt; very</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; small geometries, and in some cases it =
takes 2 minutes or more.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; I would like you to give me some clue, =
because I've worked with</FONT>
<BR><FONT SIZE=3D2>&gt; postgis</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; and shps and I've never had this kind of =
problems.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; All the geometries are indexed.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; The time responses are almost the same =
working with ORACLESPATIAL</FONT>
<BR><FONT SIZE=3D2>and</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; OGR connection.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; For example:</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; The command:</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; ogrinfo OCI:xxx/xxx at xxx -sql &quot;SELECT =
ID, ORA_GEOMETRY, NOMBRE FROM</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; SIG_DEPTOS&quot;</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Takes 1 minute.</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; The same geometry in shp:</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; ogrinfo -al departamentos.shp</FONT>
<BR><FONT SIZE=3D2>&gt; &gt; Takes less than one second.</FONT>
<BR><FONT SIZE=3D2>&gt; Vladimir,</FONT>
<BR><FONT SIZE=3D2>&gt; I can think of a couple of issues.</FONT>
<BR><FONT SIZE=3D2>&gt; First, the connection overhead to Oracle tends =
to be pretty expensive.</FONT>
<BR><FONT SIZE=3D2>&gt; In my work it was several seconds to a local =
Oracle instance.=A0 When</FONT>
<BR><FONT SIZE=3D2>&gt; using</FONT>
<BR><FONT SIZE=3D2>&gt; MapServer in &quot;cgi&quot; mode where a new =
process is forked and needs to</FONT>
<BR><FONT SIZE=3D2>&gt; connect</FONT>
<BR><FONT SIZE=3D2>&gt; to Oracle for each map request the extra =
overhead can be quite</FONT>
<BR><FONT SIZE=3D2>&gt; devestating.</FONT>
<BR><FONT SIZE=3D2>&gt; The presume solution to this is to keep the =
process resident, for</FONT>
<BR><FONT SIZE=3D2>&gt; instance</FONT>
<BR><FONT SIZE=3D2>&gt; by using FastCGI and caching the oracle =
connection.=A0 This is currently</FONT>
<BR><FONT SIZE=3D2>&gt; not supported by MapServer, but I am working on =
FastCGI support again</FONT>
</P>
<P><FONT SIZE=3D2>&gt; on</FONT>
<BR><FONT SIZE=3D2>&gt; behalf of Refractions and so a solution may =
become available in the</FONT>
<BR><FONT SIZE=3D2>&gt; coming</FONT>
<BR><FONT SIZE=3D2>&gt; months.</FONT>
<BR><FONT SIZE=3D2>&gt; Second, by default OGR will collect schema =
information from all the</FONT>
<BR><FONT SIZE=3D2>&gt; tables (or at least spatial tables) in your =
database. This can be very</FONT>
<BR><FONT SIZE=3D2>&gt; expensive for a database with alot of =
tables.=A0 However, this issue is</FONT>
<BR><FONT SIZE=3D2>&gt; unique to OGR connections to Oracle, and should =
not occur with the</FONT>
<BR><FONT SIZE=3D2>more</FONT>
<BR><FONT SIZE=3D2>&gt; direct Oracle support in MapServer.</FONT>
<BR><FONT SIZE=3D2>&gt; Best regards,</FONT>
<BR><FONT SIZE=3D2>&gt; --</FONT>
<BR><FONT SIZE=3D2>&gt; --------------------------------------- </FONT>
<BR><FONT SIZE=3D2>&gt; +--------------------------------</FONT>
<BR><FONT SIZE=3D2>&gt; ------</FONT>
<BR><FONT SIZE=3D2>&gt; I set the clouds in motion - turn up=A0=A0 | =
Frank Warmerdam,</FONT>
<BR><FONT SIZE=3D2>&gt; warmerdam at pobox.com</FONT>
<BR><FONT SIZE=3D2>&gt; light and sound - activate the windows | <A =
HREF=3D"http://pobox.com/~warmerdam" =
TARGET=3D"_blank">http://pobox.com/~warmerdam</A></FONT>
<BR><FONT SIZE=3D2>&gt; and watch the world go round - Rush=A0=A0=A0 | =
Geospatial Programmer for</FONT>
<BR><FONT SIZE=3D2>Rent</FONT>
<BR><FONT SIZE=3D2>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Paul Ramsey</FONT>
<BR><FONT SIZE=3D2>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Refractions =
Research</FONT>
<BR><FONT SIZE=3D2>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Email: =
pramsey at refractions.net</FONT>
<BR><FONT SIZE=3D2>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Phone: (250) =
885-0632</FONT>
</P>
</BODY>
</HTML>
------_=_NextPart_001_01C4A3F7.F6FEF972--
