PostGIS Bug 1587 (was Release Candidate 3)
Sean Gillies
sgillies at FRII.COM
Thu Jan 19 10:38:11 EST 2006
I just applied Umberto's patch to 4.8 and python/tests/cases/
pgtest.py runs just fine. Without this patch, it is possible that
users could get into trouble connecting to separate databases from
the same map if byte order differs between the DB platforms.
Sean
On Jan 19, 2006, at 8:10 AM, Steve Lime wrote:
> I see no one from Refractions has commented one way or the other.
> It would =
> be nice to get Paul or one of his technical folks to at least bless
> the =
> patch before modifying their module. I think someone from that
> group still =
> hangs out here occationally...
> Steve
>>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/19/06 8:20 AM
> Hi,
> do you think this bug could be fixed before 4.8 gets out?
> http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D1587
> It's been there for a month and it looks like a trivial patch to me. I
> have tested the patch on 4.6.2.
> Best regards,
> Umberto
