PostGIS Bug 1587 (was Release Candidate 3)
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Thu Jan 19 10:41:54 EST 2006
A big thanks from Italy!
So is it gonna make it for 4.8?
Regards,
Umberto
On 1/19/06, Sean Gillies <sgillies at frii.com> wrote:
> I just applied Umberto's patch to 4.8 and python/tests/cases/
> pgtest.py runs just fine. Without this patch, it is possible that
> users could get into trouble connecting to separate databases from
> the same map if byte order differs between the DB platforms.
> Sean
> On Jan 19, 2006, at 8:10 AM, Steve Lime wrote:
> > I see no one from Refractions has commented one way or the other.
> > It would =
> > be nice to get Paul or one of his technical folks to at least bless
> > the =
> > patch before modifying their module. I think someone from that
> > group still =
> > hangs out here occationally...
> > Steve
> >>>> Umberto Nicoletti <umberto.nicoletti at GMAIL.COM> 01/19/06 8:20 AM
> > Hi,
> > do you think this bug could be fixed before 4.8 gets out?
> > http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=3D1587
> > It's been there for a month and it looks like a trivial patch to me. I
> > have tested the patch on 4.6.2.
> > Best regards,
> > Umberto
