Perl module version checking
Steve Lime Steve.Lime at DNR.STATE.MN.US
Fri Nov 24 15:14:44 EST 2006
Tom: I'll check out those docs you mention.
One easy way to do this is via map.h:
#ifdef SWIG
#define VERSION MS_VERSION
#endif
This worked just fine...
Steve
>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 11/21/06 7:21 AM
Chec out section 26.4.3.  This is essentially what we want to do,
defining VERSION (equal to MS_VERSION).  I tried setting:
...which didn't work (after re-swigging things, perl Makefile.PL, make).
> -----Original Message-----
> From: Ari Jolma [mailto:ari.jolma at tkk.fi]
> Sent: 21 November, 2006 1:42 AM
> To: Kralidis,Tom [Burlington]
> Cc: Steve Lime; MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] Perl module version checking
> Kralidis,Tom [Burlington] kirjoitti:
> > I know.  I've yet to find anything to achieve this in swig.
>  Perhaps
> > Ari
> > (cc'd) can confirm.
> Swig supports different languages differently. Currently swig
> has some support for inserting Perl into the .pm files
> http://www.swig.org/Doc1.3/Perl5.html#Perl5_nn47
> I'd also like to know how this could be exploited. There are
> things that I'd like to insert into GDAL/OGR modules.
> Ari
> > ..Tom
> >> From: UMN MapServer Developers List
> >> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Steve Lime
> >> Sent: 20 November, 2006 1:37 PM
> >> To: MAPSERVER-DEV at LISTS.UMN.EDU
> >> It seems a bit hacky, which may be a good thing. I thought
> Swig had a
> >> method for including scripting language code directly into
> the module
> >> to achieve the same result. Don't know if it's worth investigating.
> >> Steve
> >>>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 11/17/2006
> >> 9:59:43 PM >>>
> >> I discussed this with Ari (cc'd), and seems the way to make this
> >> happen is to insert:
> >> $VERSION = 4.10.0;
> >> ...in mapscript.pm
> >> So, if the process for building perl mapscript is:
> >> - cd mapscript/perl/
> >> - run swig (outputs mapscript.pm)
> >> - perl Makefile.PL
> >> - make
> >> - make install
> >> Then mapscript/perl/Makefile.PL is where this logic should exist.
> >> I have locally edited mapscript/perl/Makefile.PL with the
> following,
> >> starting at line 38:
> >> open(FH, "+<mapscript.pm") or die "mapscript.pm doesn't
> exist.  You
> >> must run swig to create mapscript.pm first.  See README for more
> >> information\n"; @array = <FH>; $array[10] = "\$VERSION =
> >> $ms_version;\n";
> >> seek(FH,0,0) or die "Seeking: $!";
> >> print FH @array or die "Printing: $!";
> >> truncate(FH,tell(FH)) or die "Truncating: $!";
> >> close(FH) or die "Closing: $!";
> >> I've tried this and tested and it works fine.  Just wanting to
> >> confirm I haven't overlooked anything before committing.
> >> Cheers
> >> ..Tom
> >>> Sent: 16 November, 2006 11:35 AM
> >>> I sounds useful to me. If not for other languages then
> perhaps this
> >>> could be done through the plmodule.i interface file. This
> >> must be done
> >>> fairly often and documented someplace on the Swig website.
> >>> Steve
> >>>>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 11/15/2006
> >>> 2:18:57 PM >>>
> >>> Hi,
> >>> Mapscript defines MS_VERSION to derive the version of
> >> mapscript used
> >>> (i.e. 4.10.0, etc.).
> >>> Perl language allows for specifying modules by version, i.e.:
> >>> #!/usr/bin/perl
> >>> use strict;
> >>> use warnings;
> >>> use mapscript 4.10.0;
> >>> Perl language processes this by checking the version
> >> specified against
> >>> the VERSION variable used to identify Perl
> >> modules.
> >>> When attempting the script snippet above, the result is:
> >>> mapscript does not define $mapscript::VERSION--version
> >> check failed at
> >>> proxim2prop.pl line 9.
> >>> BEGIN failed--compilation aborted at foo.pl line 9.
> >>> I have run into a couple of situations where version
> checking like
> >>> this is required.
> >>> Suggest we add a VERSION variable to mapscript.pm.  I think
> >> it would
> >>> be valuable given the issue above, and especially since
> it is Perl
> >>> idiom to do so.
> >>> Comments?
> >>> ..Tom
> Prof. Ari Jolma
> Geoinformaatio- ja paikannustekniikka
> Geoinformation and positioning technology Teknillinen
> Korkeakoulu / Helsinki University of Technology POBox 1200,
> 02015 TKK, Finland
> Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
