Perl module version checking
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Sun Nov 26 22:15:56 EST 2006
Steve,
I tried this out.  For some reason, when I try to ./configure, I get:
config.status: creating Makefile
sed: file ./confstatAG8117/subs-2.sed line 6: unterminated `s' command
config.status: creating mapscript/php3/Makefile
config.status: creating mapscript/java/Makefile
config.status: creating mapscript/csharp/Makefile
> -----Original Message-----
> From: Steve Lime [mailto:Steve.Lime at dnr.state.mn.us]
> Sent: 24 November, 2006 3:15 PM
> To: Kralidis,Tom [Burlington]; MAPSERVER-DEV at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-DEV] Perl module version checking
> Tom: I'll check out those docs you mention.
> One easy way to do this is via map.h:
> #ifdef SWIG
> #define VERSION MS_VERSION
> #endif
> This worked just fine...
> Steve
> >>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA>
> 11/21/06 7:21 AM
> Chec out section 26.4.3.  This is essentially what we want to
> do, defining VERSION (equal to MS_VERSION).  I tried setting:
> ...which didn't work (after re-swigging things, perl
> Makefile.PL, make).
> > From: Ari Jolma [mailto:ari.jolma at tkk.fi]
> > Sent: 21 November, 2006 1:42 AM
> > Cc: Steve Lime; MAPSERVER-DEV at LISTS.UMN.EDU
> > Kralidis,Tom [Burlington] kirjoitti:
> > > I know.  I've yet to find anything to achieve this in swig.
> >  Perhaps
> > > Ari
> > > (cc'd) can confirm.
> > Swig supports different languages differently. Currently
> swig has some
> > support for inserting Perl into the .pm files
> > http://www.swig.org/Doc1.3/Perl5.html#Perl5_nn47
> > I'd also like to know how this could be exploited. There are things
> > that I'd like to insert into GDAL/OGR modules.
> > Ari
> > > ..Tom
> > >> From: UMN MapServer Developers List
> > >> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Steve Lime
> > >> Sent: 20 November, 2006 1:37 PM
> > >> To: MAPSERVER-DEV at LISTS.UMN.EDU
> > >> It seems a bit hacky, which may be a good thing. I thought
> > Swig had a
> > >> method for including scripting language code directly into
> > the module
> > >> to achieve the same result. Don't know if it's worth
> investigating.
> > >> Steve
> > >>>>> "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA> 11/17/2006
> > >> 9:59:43 PM >>>
> > >> I discussed this with Ari (cc'd), and seems the way to make this
> > >> happen is to insert:
> > >> $VERSION = 4.10.0;
> > >> ...in mapscript.pm
> > >> So, if the process for building perl mapscript is:
> > >> - cd mapscript/perl/
> > >> - run swig (outputs mapscript.pm)
> > >> - perl Makefile.PL
> > >> - make
> > >> - make install
> > >> Then mapscript/perl/Makefile.PL is where this logic should exist.
> > >> I have locally edited mapscript/perl/Makefile.PL with the
> > following,
> > >> starting at line 38:
> > >> open(FH, "+<mapscript.pm") or die "mapscript.pm doesn't
> > exist.  You
> > >> must run swig to create mapscript.pm first.  See README for more
> > >> information\n"; @array = <FH>; $array[10] = "\$VERSION =
> > >> $ms_version;\n";
> > >> seek(FH,0,0) or die "Seeking: $!";
> > >> print FH @array or die "Printing: $!";
> > >> truncate(FH,tell(FH)) or die "Truncating: $!";
> > >> close(FH) or die "Closing: $!";
> > >> I've tried this and tested and it works fine.  Just wanting to
> > >> confirm I haven't overlooked anything before committing.
> > >> Cheers
> > >> ..Tom
> > >>> Sent: 16 November, 2006 11:35 AM
> > >>> I sounds useful to me. If not for other languages then
> > perhaps this
> > >>> could be done through the plmodule.i interface file. This
> > >> must be done
> > >>> fairly often and documented someplace on the Swig website.
> > >>> Steve
> 11/15/2006
> > >>> 2:18:57 PM >>>
> > >>> Hi,
> > >>> Mapscript defines MS_VERSION to derive the version of
> > >> mapscript used
> > >>> (i.e. 4.10.0, etc.).
> > >>> Perl language allows for specifying modules by version, i.e.:
> > >>> #!/usr/bin/perl
> > >>> use strict;
> > >>> use warnings;
> > >>> use mapscript 4.10.0;
> > >>> Perl language processes this by checking the version
> > >> specified against
> > >>> the VERSION variable used to identify Perl
> > >> modules.
> > >>> When attempting the script snippet above, the result is:
> > >>> mapscript does not define $mapscript::VERSION--version
> > >> check failed at
> > >>> proxim2prop.pl line 9.
> > >>> BEGIN failed--compilation aborted at foo.pl line 9.
> > >>> I have run into a couple of situations where version
> > checking like
> > >>> this is required.
> > >>> Suggest we add a VERSION variable to mapscript.pm.  I think
> > >> it would
> > >>> be valuable given the issue above, and especially since
> > it is Perl
> > >>> idiom to do so.
> > >>> Comments?
> > >>> ..Tom
> > Prof. Ari Jolma
> > Geoinformaatio- ja paikannustekniikka
> > Geoinformation and positioning technology Teknillinen Korkeakoulu /
> > Helsinki University of Technology POBox 1200,
> > 02015 TKK, Finland
> > Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
