Use of static var in MapScript mapObj.nextLabel
Tamas Szekeres szekerest at GMAIL.COM
Wed Jul 4 16:46:15 EDT 2007
Daniel,
I agree with the plan as well.
I'm curious to know the use cases either. In the -users list we might
have more success about that.
Best regards,
Tamas
2007/7/4, Daniel Morissette <dmorissette at mapgears.com>:
> I agree with both of you!  ;)
> I mean:
> - I agree it's a bad idea to keep client related state (such as last
> label read) in a static var, or even in something like a mapObj.
> - I agree that we should not remove interfaces that are in significant
> use and should try to maintain backwards compatibility as much as possible.
> That being said, since my original post I have found out that
> map.nextLabel() was never fully implemented in PHP MapScript, so this
> method is not used at all in PHP. And if PHP users never asked for it I
> doubt other MapScript users use it much. Did anyone on this list ever
> use map.nextLabel() or map.getLabel(int i) in SWIG MapScript?
> Actually, what's the use of reading label cache members? What would a
> script do with them? I am trying to understand the use case and figure
> what use there is for a nextLabel() or getLabel() method if any.
> Doing a search in Trac I found ticket 1794 which talks about the
> addition of getLabel(i) to solve the static var issue but doesn't
> describe the actual use case:
> https://trac.osgeo.org/mapserver/ticket/1794
> I was not aware of getLabel(int i) until I read Tamas' message. If we
> find real use cases for reading label cache members then I think
> getLabel(int i) is a better interface. I think nextLabel() should go
> away because it could never be practically used anyway since there was
> no way to reset the iteration and its state was global to the current
> process.
> Finally, the reason why I bring up all that is that with the
> labelCacheObj becoming an array of cache slots for each priority level,
> labelCache.numlabels would disappear (and be replaced by a numlabels for
> each slot) so we are already going to break backwards compatibility for
> the very few users (if any) of getLabel(i) that rely on
> map->labelcache>numlabels.
> I propose that, assuming there is a real use case for getLabel(i), we
> make the following changes required to support the new label priority
> stuff and solve the current issue:
> 1- In SWIG MapSCript:
>    1a- Get rid of mapObj.nextLabel() as it's broken and nearly useless.
>    1b- Deprecate mapObj.getLabel(int i), to be removed in a future release.
>    1c- labelCacheObj.numlabels will be maintained artificially for
> backwards compatibility but will be deprecated, to be removed in a
> future release
> 2- In both SWIG and PHP MapScript:
>    2a- Add labelCacheObj.getNumLabels()
>    2b- Add labelCacheObj.getLabel(int i)
> Does that sounds like an acceptable plan?
> Daniel
> Tamas Szekeres wrote:
> > Frank,
> > I don't object keeping this function until some further releases as it
> > stands now.
> > However I don't favour introducing the practice of keeping much of the
> > client related state (like the state of an iteration) inside the
> > mapserver core.
> > Best regards,
> > Tamas
> > 2007/7/1, Frank Warmerdam <warmerdam at pobox.com>:
> >> >> As the "Ghost of Backward Compatability" I'd rather not get rid of
> >> >> getNextLabel() if it is in significant use without a very serious
> >> reason.
> >> >> We might however make an effort to deprecate it in favor of
> >> >> getLabel(int i).
> >> > Frank,
> >> > The next major release is the best option to get rid of the unwanted
> >> > parts of the interface.
> >> > Moreover the current nextLabel is quite unconventional and does not
> >> > allow the client to reset the iteration. I have no idea what is the
> >> > desired use this function then. When we build up a loop until the
> >> > returned value is null we might not get all of the results back. It's
> >> > definitely unfeasible. Though we are thinking of that support of
> >> > resetting the iteration, I guess it goes against the idea of the
> >> > deprecation.
> >> Tamas,
> >> Well, I respectfully disagree.  If the interface works, and is in
> >> reasonably widespread use, and we have no compelling reason for
> >> removing it then I don't think we should remove it.
> >> Changing stuff like this is going to be a poke in the eye for folks
> >> trying to maintain higher level applications, especially if they would
> >> like them to work with 4.10 and 5.0.
> >> Deprecating normally involves advising that a particular interface is
> >> no longer intended for use, but not actually removing it for some
> >> time into the future (perhaps at MapServer 6.0).
> >> On the other hand, this might be a good time to remove some cruft
> >> that we deprecated at 4.0.
> >> I'm not a genius programmer, and I'm not particularly skilled at
> >> web applications.  But there is one thing that I know.  Interface
> >> churn costs user-base, and a stable API shows love for the user-base.
> >> Best regards,
> >> I set the clouds in motion - turn up   | Frank Warmerdam,
> >> light and sound - activate the windows | http://pobox.com/~warmerdam
> >> and watch the world go round - Rush    | President OSGeo,
> >> http://osgeo.org
> Daniel Morissette
> http://www.mapgears.com/
