Use of static var in MapScript mapObj.nextLabel
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Wed Jul 4 16:55:56 EDT 2007
Where2getit does a lot of Perl mapscript and we have never used
map.nextLabel() or map.getLabel()
I've also never used it on any other projects. I'm not sure how it might
be of use.
-Steve W.
Tamas Szekeres wrote:
> Daniel,
> I agree with the plan as well.
> I'm curious to know the use cases either. In the -users list we might
> have more success about that.
> Best regards,
> Tamas
> 2007/7/4, Daniel Morissette <dmorissette at mapgears.com>:
>> I agree with both of you! ;)
>> I mean:
>> - I agree it's a bad idea to keep client related state (such as last
>> label read) in a static var, or even in something like a mapObj.
>> - I agree that we should not remove interfaces that are in significant
>> use and should try to maintain backwards compatibility as much as
>> possible.
>> That being said, since my original post I have found out that
>> map.nextLabel() was never fully implemented in PHP MapScript, so this
>> method is not used at all in PHP. And if PHP users never asked for it I
>> doubt other MapScript users use it much. Did anyone on this list ever
>> use map.nextLabel() or map.getLabel(int i) in SWIG MapScript?
>> Actually, what's the use of reading label cache members? What would a
>> script do with them? I am trying to understand the use case and figure
>> what use there is for a nextLabel() or getLabel() method if any.
>> Doing a search in Trac I found ticket 1794 which talks about the
>> addition of getLabel(i) to solve the static var issue but doesn't
>> describe the actual use case:
>> https://trac.osgeo.org/mapserver/ticket/1794
>> I was not aware of getLabel(int i) until I read Tamas' message. If we
>> find real use cases for reading label cache members then I think
>> getLabel(int i) is a better interface. I think nextLabel() should go
>> away because it could never be practically used anyway since there was
>> no way to reset the iteration and its state was global to the current
>> process.
>> Finally, the reason why I bring up all that is that with the
>> labelCacheObj becoming an array of cache slots for each priority level,
>> labelCache.numlabels would disappear (and be replaced by a numlabels for
>> each slot) so we are already going to break backwards compatibility for
>> the very few users (if any) of getLabel(i) that rely on
>> map->labelcache>numlabels.
>> I propose that, assuming there is a real use case for getLabel(i), we
>> make the following changes required to support the new label priority
>> stuff and solve the current issue:
>> 1- In SWIG MapSCript:
>> 1a- Get rid of mapObj.nextLabel() as it's broken and nearly useless.
>> 1b- Deprecate mapObj.getLabel(int i), to be removed in a future
>> release.
>> 1c- labelCacheObj.numlabels will be maintained artificially for
>> backwards compatibility but will be deprecated, to be removed in a
>> future release
>> 2- In both SWIG and PHP MapScript:
>> 2a- Add labelCacheObj.getNumLabels()
>> 2b- Add labelCacheObj.getLabel(int i)
>> Does that sounds like an acceptable plan?
>> Daniel
>> > Frank,
>> > I don't object keeping this function until some further releases as it
>> > stands now.
>> > However I don't favour introducing the practice of keeping much of the
>> > client related state (like the state of an iteration) inside the
>> > mapserver core.
>> > Best regards,
>> > Tamas
>> > 2007/7/1, Frank Warmerdam <warmerdam at pobox.com>:
>> >> >> As the "Ghost of Backward Compatability" I'd rather not get rid of
>> >> >> getNextLabel() if it is in significant use without a very serious
>> >> reason.
>> >> >> We might however make an effort to deprecate it in favor of
>> >> >> getLabel(int i).
>> >> > Frank,
>> >> > The next major release is the best option to get rid of the unwanted
>> >> > parts of the interface.
>> >> > Moreover the current nextLabel is quite unconventional and does not
>> >> > allow the client to reset the iteration. I have no idea what is the
>> >> > desired use this function then. When we build up a loop until the
>> >> > returned value is null we might not get all of the results back.
>> It's
>> >> > definitely unfeasible. Though we are thinking of that support of
>> >> > resetting the iteration, I guess it goes against the idea of the
>> >> > deprecation.
>> >> Tamas,
>> >> Well, I respectfully disagree. If the interface works, and is in
>> >> reasonably widespread use, and we have no compelling reason for
>> >> removing it then I don't think we should remove it.
>> >> Changing stuff like this is going to be a poke in the eye for folks
>> >> trying to maintain higher level applications, especially if they would
>> >> like them to work with 4.10 and 5.0.
>> >> Deprecating normally involves advising that a particular interface is
>> >> no longer intended for use, but not actually removing it for some
>> >> time into the future (perhaps at MapServer 6.0).
>> >> On the other hand, this might be a good time to remove some cruft
>> >> that we deprecated at 4.0.
>> >> I'm not a genius programmer, and I'm not particularly skilled at
>> >> web applications. But there is one thing that I know. Interface
>> >> churn costs user-base, and a stable API shows love for the user-base.
>> >> Best regards,
>> >> I set the clouds in motion - turn up | Frank Warmerdam,
>> >> light and sound - activate the windows | http://pobox.com/~warmerdam
>> >> and watch the world go round - Rush | President OSGeo,
>> >> http://osgeo.org
>> Daniel Morissette
>> http://www.mapgears.com/
