SV: More of pooling, mapquery.c
Hallgren Johan E jhhal at WMDATA.COM
Mon May 7 14:07:58 EDT 2007
Thanks again Tamas (and other),
I have missed that piece. It could be the missing part.
I will try it tomorrow.
Thanks again,
Johan
___________________________________
Johan Hallgren
WM-data
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel (och mobil): 023-547 46 (int: +46-2354746)
johan.e.hallgren at wmdata.com <mailto:johan.e.hallgren at wmdata.com>
http://www.wmdata.se <https://webaccess.wmdata.com/exchweb/bin/redir.asp?URL=http://www.wmdata.se/>
Från: Tamas Szekeres [mailto:szekerest at gmail.com]
Skickat: må 2007-05-07 14:17
Till: Hallgren Johan E
Kopia: MAPSERVER-DEV at lists.umn.edu
Ämne: Re: More of pooling, mapquery.c
Did you test with
PROCESSING CLOSE_CONNECTION=DEFER option with your SDE layer?
Best regards,
Tamas
2007/5/7, Hallgren Johan E <jhhal at wmdata.com>:
> Hello again,
> I have made a test with the following code with extremely good performance.
> I have only tested this specific call, but couldn't the concept be
> implemented in other functions as well? As I see it, it will implement the
> Connection pool between mapscript calls.
> My added sections start with Johan START and ends with Johan END.
> int msQueryByAttributes(mapObj *map, int qlayer, char *qitem, char *qstring,
> int mode)
>   layerObj *lp;
>   int status;
>   /* Johan START */
>   int bLayerWasOpen;
>   /* Johan START */
>   int old_filtertype=-1;
>   char *old_filterstring=NULL, *old_filteritem=NULL;
>   rectObj searchrect;
>   shapeObj shape;
>   if(qlayer < 0 || qlayer >= map->numlayers) {
>     msSetError(MS_MISCERR, "No query layer defined.",
> "msQueryByAttributes()");
>     return(MS_FAILURE);
>   lp = &(map->layers[qlayer]);
>   /* free any previous search results, do now in case one of the following
> tests fails */
>   if(lp->resultcache) {
>     if(lp->resultcache->results) free(lp->resultcache->results);
>     free(lp->resultcache);
>     lp->resultcache = NULL;
>   if(!msIsLayerQueryable(lp)) {
>     msSetError(MS_QUERYERR, "Requested layer has no templates defined so is
> not queryable.", "msQueryByAttributes()");
>     return(MS_FAILURE);
>   if(!qstring) {
>     msSetError(MS_QUERYERR, "No query expression defined.",
>     return(MS_FAILURE);
>   /* save any previously defined filter */
>   if(lp->filter.string) {
>     old_filtertype = lp->filter.type;
>     old_filterstring = strdup(lp->filter.string);
>     if(lp->filteritem)
>       old_filteritem = strdup(lp->filteritem);
>   /* apply the passed query parameters */
>   if(qitem)
>     lp->filteritem = strdup(qitem);
>   else
>     lp->filteritem = NULL;
>   msLoadExpressionString(&(lp->filter), qstring);
>   msInitShape(&shape);
>   /* open this layer */
>       /* Johan START */
>       //int bLayerWasOpen;
>       bLayerWasOpen = msLayerIsOpen(lp);
>   if (!bLayerWasOpen)
>             status = msLayerOpen(lp);
>             if(status != MS_SUCCESS) return(MS_FAILURE);
>       //status = msLayerOpen(lp);
>  // if(status != MS_SUCCESS) return(MS_FAILURE);
>       /*Johan END*/
>   /* build item list (no annotation) */
>   status = msLayerWhichItems(lp, MS_TRUE, MS_FALSE, NULL);
>   /* identify target shapes */
>   searchrect = map->extent;
> #ifdef USE_PROJ
>   if(lp->project && msProjectionsDiffer(&(lp->projection),
> &(map->projection)))
>     msProjectRect(&(map->projection), &(lp->projection),
> &searchrect); /* project the searchrect to source coords */
>   else
>     lp->project = MS_FALSE;
> #endif
>   status = msLayerWhichShapes(lp, searchrect);
>   if(status == MS_DONE) { /* no overlap */
>     msLayerClose(lp);
>     msSetError(MS_NOTFOUND, "No matching record(s) found, layer and area of
> interest do not overlap.", "msQueryByAttributes()");
>     return(MS_FAILURE);
>   } else if(status != MS_SUCCESS) {
>     msLayerClose(lp);
>     return(MS_FAILURE);
>   lp->resultcache = (resultCacheObj *)malloc(sizeof(resultCacheObj)); /*
> allocate and initialize the result cache */
>   lp->resultcache->results = NULL;
>   lp->resultcache->numresults = lp->resultcache->cachesize = 0;
>   lp->resultcache->bounds.minx = lp->resultcache->bounds.miny =
> lp->resultcache->bounds.maxx = lp->resultcache->bounds.maxy = -1;
>   while((status = msLayerNextShape(lp, &shape)) == MS_SUCCESS) { /* step
> through the shapes */
>     shape.classindex = msShapeGetClass(lp, &shape, map->scale);
>     if(!(lp->template) && ((shape.classindex == -1) ||
> (lp->class[shape.classindex].status == MS_OFF))) { /* not a valid shape */
>       msFreeShape(&shape);
>       continue;
>     if(!(lp->template) && !(lp->class[shape.classindex].template)) { /* no
> valid template */
>       continue;
> #ifdef USE_PROJ
>     if(lp->project &&
> msProjectionsDiffer(&(lp->projection), &(map->projection)))
>       msProjectShape(&(lp->projection), &(map->projection),
> &shape);
>     else
> #endif
>     addResult(lp->resultcache, shape.classindex, shape.index,
> shape.tileindex);
>     if(lp->resultcache->numresults == 1)
>       lp->resultcache->bounds = shape.bounds;
>     else
>       msMergeRect(&(lp->resultcache->bounds),
> &shape.bounds);
>     if(mode == MS_SINGLE) { /* no need to look any further */
>       status = MS_DONE;
>       break;
>   if(status != MS_DONE) return(MS_FAILURE);
>   /* the FILTER set was just temporary, clean up here */
>   freeExpression(&(lp->filter));
>   if(lp->filteritem) {
>     free(lp->filteritem);
>     lp->filteritemindex = -1;
>   /* restore any previously defined filter */
>   if(old_filterstring) {
>     lp->filter.type = old_filtertype;
>     lp->filter.string = strdup(old_filterstring);
>     free(old_filterstring);
>     if(old_filteritem) {
>       lp->filteritem = strdup(old_filteritem);
>       free(old_filteritem);
>       /*Johan START*/
>   if (!bLayerWasOpen)
>             msLayerClose(lp);
>       //msLayerClose(lp);
>       /*Johan END*/
>   /* was anything found?  */
>   if(lp->resultcache && lp->resultcache->numresults > 0)
>     return(MS_SUCCESS);
>   msSetError(MS_NOTFOUND, "No matching record(s) found.",
>   return(MS_FAILURE);
> /Ugh
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> http://www.wmdata.se <http://www.wmdata.se/>
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070507/2a0877ac/attachment.html
