[mapserver-dev] Re: Changing the connectiontype with the mapscript
	interface doesn't change the vtable.
    Daniel Morissette
    dmorissette at mapgears.com
    Wed Aug 13 10:13:24 EDT 2008
Tamas,
I saw that you added this in r7845 a few minutes ago, but would have a
few comments/questions:
1- What value should be passed to the library_str arg? That's not
specified in the docs that you created in mapscript.txt
2- The new method is called layerObj.connectLayer() ... would it not be
better call it layerObj.setConnectionType()? It seems to me that
setConnectionType() would be more meaningful since it's not opening an
actual connection contrary to what the verb "connect" suggests, and it's
also not setting the layer->connection value, it's just setting the
connection type params, right?
Daniel
Tamas Szekeres wrote:
> Or this way ;-)
> int ConnectLayer(int connectiontype,
>                             char *library_str)
>         msConnectLayer(self, connectiontype, library_str);
> 2008/8/12 Tamas Szekeres <szekerest at gmail.com>:
>> Hmmm. What I really want to do is to expose msConnectLayer in layer.i:
>>                            char *library_str)
>>                   const int connectiontype,
>>                   const char *library_str)
>> Tamas
>>> Devs,
>>> By changing the connectiontype at the SWIG interface the vtable will
>>> not change accordingly so the vtable function of the old
>>> connectiontype will be called.
>>> Do we have a method to reset the vtable in this case or should we
>>> probably implement a layerObj.setConnectionType  for this purpose?
>>> Best regards,
>>> Tamas
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
http://www.mapgears.com/
