[mapserver-dev] mapsde : qualified names vs non qualified names
Yewondwossen Assefa yassefa at dmsolutions.ca
Thu Feb 21 10:13:08 EST 2008
Howard Butler wrote:
> On Feb 20, 2008, at 5:55 PM, Yewondwossen Assefa wrote:
>> Hi There,
>> Working with mapserver/sde layers, we came across an issue  where the
>> attribute names used (ex for a querybyattributes) must be qualified if
>> there is a Join done on the layer and non-qualified if there is no
>> join. Note that this is documented.
>> Do you see any advantage/problem to always be able to use qualified
>> names either there is a join or not? At least be able for those who
>> want it, to be able to have a setting so that qualified names are
>> always used. (this would preserve the way it works now if there is
>> nothing set)
> Assefa,
> If I remember correctly, I had a lot of trouble with qualified names and
> joins with SDE.  I settled with what we have now to attempt to preserve
> existing behavior for folks while still allowing in-database joins to
> happen.  I would support adding some sort of PROCESSING item to switch
> on fully qualified names, or if there is enough support for 5.2, just
> moving to always returning and using qualified names (this would require
> mapfile changes for folks, however).
> Howard
  Thanks Howard. I have create a enhancement bug on it
http://trac.osgeo.org/mapserver/ticket/2523 and put a patch that can be
used to always use qualified names with a processing setting.  It can be
reviewed and applied if make sense.
Best Regards,
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
