[mapserver-dev] IGNORE_MISSING_DATA
Paul Ramsey pramsey at cleverelephant.ca
Fri Oct 10 15:08:52 EDT 2008
Anyone, anyone, Beuhler?
On Thu, Oct 9, 2008 at 12:45 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> On Thu, Oct 9, 2008 at 1:30 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com> wrote:
>>> Thoughts on the actual configuration mechanism, would be most appreciated.
>> I presume that you are asking how to get the compile time option to be
>> reflected in the code?
> No, I mean, is the idea of a map file parameter "ON_MISSING_DATA"
> disgusting, or desirable, is there a better name, a better approach?
> Should something more off-to-the-side like PROCESSING directives be
> used? Basically what should the user-facing aspect of this
> functionality look like?
