[mapserver-dev] build warnings
Kralidis,Tom [Burlington] Tom.Kralidis at ec.gc.ca
Thu Oct 23 07:19:54 EDT 2008
Hi: I just upgraded my dev box to fc9, and when make clean &&
./configure... && make I am introduced to a number of warnings like:
mapwms.c:49: warning: 'cvsid_aw' defined but not used
maporaclespatial.c:42: warning: 'cvsid_aw' defined but not used
mapgml.c:34: warning: 'cvsid_aw' defined but not used
mapthread.c:140: warning: 'cvsid_aw' defined but not used
mapdraw.c:35: warning: 'cvsid_aw' defined but not used
FYI I never had these errors prior to upgrading to fc9.
OS: fc9
Uname: Linux devgeo 2.6.26.5-45.fc9.i686 #1 SMP Sat Sep 20 03:45:00 EDT
2008 i686 i686 i386 GNU/Linux
gcc -v
Using built-in specs.
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info
--with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap
--enable-shared --enable-threads=posix --enable-checking=release
--with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions
--enable-languages=c,c++,objc,obj-c++,java,fortran,ada
--enable-java-awt=gtk --disable-dssi --enable-plugin
--with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre
--enable-libgcj-multifile --enable-java-maintainer-mode
--with-ecj-jar=/usr/share/java/eclipse-ecj.jar
--disable-libjava-multilib --with-cpu=generic --build=i386-redhat-linux
Thread model: posix
gcc version 4.3.0 20080428 (Red Hat 4.3.0-8) (GCC)
MapServer: svn trunk
configure: ./configure --enable-debug
--with-freetype=/usr/bin/freetype-config --with-zlib=/usr
--with-png=/usr --with-jpeg=/usr --with
-gd=/usr --with-pdf=/usr/local --with-eppl --with-proj=/usr/local
--with-ogr=/usr/local/bin/gdal-config --with-gdal=/usr/loc
al/bin/gdal-config --without-tiff --with-postgis=/usr/bin/pg_config
--with-wfs --with-wcs --with-wmsclient --with-wfsclient
--with-curl-config=/usr/bin/curl-config
--with-php=/usr/local/src/php/php-5.2.6 --with-ming=/usr/local
--with-sos --with-geo
s=/usr/local/bin/geos-config --with-agg
..Tom
