[mapserver-dev] Checking old bookmarks ....
Howard Butler hobu.inc at gmail.com
Mon Jan 5 11:13:04 EST 2009
Steve,
If you change mapserver.gis.umn.edu for ms.gis.umn.edu you can get to
the content of the old site (css is broken)
http://ms.gis.umn.edu/community/conferences/MUM3/workshop/postgis
This is expected to go down in a month, however.
A problem is all of the links the site is generating say
mapserver.gis...  I will make an attempt to fix this, but no promises.
As for the content when it goes away in a month, there's always the
wayback machine, which isn't probably a satisfactory answer.
Alternatively, if you've interest and time to pull these things
together into the new layout and system, it would be greatly
appreciated.
I think mapserverfoundation == osgeo and links could be updated to be
that in the current docs if you found any.
On Jan 5, 2009, at 9:11 AM, Stephen Woodbridge wrote:
> Found this:
>   http://www.mapserverfoundation.org/index.html
> Does this need to go away now?
> We seem to have lost documents like:
> http://mapserver.gis.umn.edu/community/conferences/MUM3/workshop/postgis/
> Where is the information on the various conferences and proceedings,
> if it is all on the osgeo site we should at least have links to the
> mapserver relevant docs.
> -Steve W
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
