[mapserver-dev] Checking old bookmarks ....
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 5 16:06:57 EST 2009
Howard,
I'm not sure it is worth your time to muck with links on a site that is
going away and is generally un-published.
My general concern is that we seem to have lost a lot of content. Now
this may be just a false impression, because you guys have done a great
job reorganizing a lot of information and moving things like wiki
comments and tips into the appropriate source documents. But that said,
it is just a little disconcerting to feel like we have lost stuff, but
can not quite put a handle on what we have lost, if anything. This will
pass as I learn where stuff is in the new site which is greatly
simplified and should be easier to navigate.
So, yes if I find stuff that I can add, or modify, etc, I will or write
a bug on it. Do you have any kind of list of stuff that did not migrate
to the new site like:
http://ms.gis.umn.edu/community/conferences/* stuff
Is the wiki gone or just moved, none of my bookmarks to the wiki worked,
but I don't frequent them so these probably broke ages ago when we moved
to the osgeo wiki or whatever. Do we still have a wiki? or did we decide
to do away with that as being to chaotic and want people to update the
svn docs.
Thanks,
   -Steve
Howard Butler wrote:
> Steve,
> If you change mapserver.gis.umn.edu for ms.gis.umn.edu you can get to
> the content of the old site (css is broken)
> http://ms.gis.umn.edu/community/conferences/MUM3/workshop/postgis
> This is expected to go down in a month, however.
> A problem is all of the links the site is generating say
> mapserver.gis...  I will make an attempt to fix this, but no promises.
> As for the content when it goes away in a month, there's always the
> wayback machine, which isn't probably a satisfactory answer.
> Alternatively, if you've interest and time to pull these things together
> into the new layout and system, it would be greatly appreciated.
> I think mapserverfoundation == osgeo and links could be updated to be
> that in the current docs if you found any.
> On Jan 5, 2009, at 9:11 AM, Stephen Woodbridge wrote:
>> Found this:
>>   http://www.mapserverfoundation.org/index.html
>> Does this need to go away now?
>> We seem to have lost documents like:
>> http://mapserver.gis.umn.edu/community/conferences/MUM3/workshop/postgis/
>> Where is the information on the various conferences and proceedings,
>> if it is all on the osgeo site we should at least have links to the
>> mapserver relevant docs.
>> -Steve W
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
