[mapserver-dev] scalebar in svg
windyhs windyhendras at gmail.com
Mon May 25 00:33:02 EDT 2009
dear all
i want to ask about mapserver
1. can mapserver showing the scalebar but in the svg format?
   i had already tried, but it didn't work.
   But if i changed the imagetype to gif or png, the scalebar show up.
2. i'm using template to show the map using the tag <form>.
   how can i show the imagefile rendered from mapserver but in the svg
format?
   what should i change in the <input> tag?
   note: i'm using tag from mapserver such as [img], etc.
   Thanks for your answer.
   Best Regard.
View this message in context: http://n2.nabble.com/scalebar-in-svg-tp2967951p2967951.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
