[mapserver-dev] DEFRESOLUTION default
Paul Ramsey pramsey at cleverelephant.ca
Fri Jan 29 11:02:51 EST 2010
I have a client w/ a similar problem. We ended up patching mapserver
to match defresolution to the resolution of their mapfiles so we could
do an upgrade in mapserver w/o changing all the mapfiles.
P.
On Fri, Jan 29, 2010 at 7:21 AM,  <bartvde at osgis.nl> wrote:
> Hi list,
> why is the default value of DEFRESOLUTION 72?
> To me a more logical default value would be MAP->RESOLUTION if it is not
> set explicitly.
> Now we have a situation in which our current MAP files under MS 5.6 have
> scaled up pixmaps, and we can't add DEFRESOLUTION to our existing MAP
> files since this breaks with MS 5.2 (unknown identifier error on
> DEFRESOLUTION).
> Best regards,
> Bart
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
