[mapserver-dev] The legendary story of mapObj.zoomRectangle (a cabaret show)
Daniel Morissette dmorissette at mapgears.com
Thu Mar 4 11:44:35 EST 2010
Once those two issues are sorted out I'll be happy to take care of
releasing 5.6.2.
Daniel
Lime, Steve D (DNR) wrote:
> I'd like to take a peek at the isValidItem() issue before doing a 5.6.2...
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan Boudreault
> Sent: Wednesday, March 03, 2010 3:47 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] The legendary story of mapObj.zoomRectangle (a cabaret show)
> Tamas,
> Someone also reported on IRC that problem (IIRC, 2-3 weeks ago). My change was
> a misinterpretation and shouldn't have been done. I had not understood why
> this part of the code was different of the php similar function. As you said
> on IRC "treating maxy >= miny as a failure is semantically irregular", but
> this commit changed the behavior of the function that exists for a long time.
> I would suggest to revert it and backport it in branch 5.6.
> Perhaps it would be a good opportunity to release 5.6.2 ? Are there enough
> important fixes in the branch?
> regards,
> Alan
> On March 3, 2010 03:49:54 pm Tamas Szekeres wrote:
>> Folks,
>> Upon upgrading my existing application to 5.6.1 I'm getting frustrated
>>  about the changes of the rectangle check in mapObj.zoomRectangle. So let
>>  me summarize how the related code have changed within the past 5 years.
>> - 2004-06-26 The stuff has been committed by sean in r3294 mapzoom.i Ln 280
>> if (poPixRect->maxy >= poPixRect->miny)
>>             msSetError(MS_MISCERR, "Georeferenced coordinates miny <=
>>  maxy", "mapscript::mapObj::zoomRectangle()");
>>             return MS_FAILURE;
>> - 2006-05-30  First attempt to swap miny and maxy by umberto in r5472
>> - 2006-07-24  The change have been reverted by hobu in r5542
>> - 2006-12-13 Second attempt to swap miny and maxy by sdlime in r5859
>> - 2006-12-13 Reverted the change by sdlime in r5864
>> - 2009-10-12 Third attempt to swap miny and maxy by aboudreault in r9444
>> There have been a couple of tickets related to this issue like:
>> http://trac.osgeo.org/mapserver/ticket/1817
>> http://trac.osgeo.org/mapserver/ticket/1982
>> http://trac.osgeo.org/mapserver/ticket/1988
>> http://trac.osgeo.org/mapserver/ticket/3286
>> While I'm a bit lost with the reason of these reverts it seems we don't
>>  have solid standpoint on how this consistency check should be done. I
>>  would anticipate I'm not against this change, however I would not want to
>>  alter my existing scipts (like now) in every release in order to have my
>>  code working.
>> Could someone confirm this change won't be reverted in the future releases?
>> Best regards,
>> Tamas
Daniel Morissette
http://www.mapgears.com/
