[mapserver-dev] The legendary story of mapObj.zoomRectangle (a cabaret show)
Alan Boudreault aboudreault at mapgears.com
Thu Mar 4 12:00:06 EST 2010
I'm going to revert the mapObj.zoomRectangle change later today or early
tomorrow.
On March 4, 2010 11:22:57 am Lime, Steve D (DNR) wrote:
> I'd like to take a peek at the isValidItem() issue before doing a 5.6.2...
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
>  [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Alan
>  Boudreault Sent: Wednesday, March 03, 2010 3:47 PM
> To: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] The legendary story of mapObj.zoomRectangle (a
>  cabaret show)
> Tamas,
> Someone also reported on IRC that problem (IIRC, 2-3 weeks ago). My change
>  was a misinterpretation and shouldn't have been done. I had not understood
>  why this part of the code was different of the php similar function. As
>  you said on IRC "treating maxy >= miny as a failure is semantically
>  irregular", but this commit changed the behavior of the function that
>  exists for a long time. I would suggest to revert it and backport it in
>  branch 5.6.
> Perhaps it would be a good opportunity to release 5.6.2 ? Are there enough
> important fixes in the branch?
> regards,
> Alan
> On March 3, 2010 03:49:54 pm Tamas Szekeres wrote:
> > Folks,
> > Upon upgrading my existing application to 5.6.1 I'm getting frustrated
> >  about the changes of the rectangle check in mapObj.zoomRectangle. So let
> >  me summarize how the related code have changed within the past 5 years.
> > - 2004-06-26 The stuff has been committed by sean in r3294 mapzoom.i Ln
> > 280 if (poPixRect->maxy >= poPixRect->miny)
> >             msSetError(MS_MISCERR, "Georeferenced coordinates miny <=
> >  maxy", "mapscript::mapObj::zoomRectangle()");
> >             return MS_FAILURE;
> > - 2006-05-30  First attempt to swap miny and maxy by umberto in r5472
> > - 2006-07-24  The change have been reverted by hobu in r5542
> > - 2006-12-13 Second attempt to swap miny and maxy by sdlime in r5859
> > - 2006-12-13 Reverted the change by sdlime in r5864
> > - 2009-10-12 Third attempt to swap miny and maxy by aboudreault in r9444
> > There have been a couple of tickets related to this issue like:
> > http://trac.osgeo.org/mapserver/ticket/1817
> > http://trac.osgeo.org/mapserver/ticket/1982
> > http://trac.osgeo.org/mapserver/ticket/1988
> > http://trac.osgeo.org/mapserver/ticket/3286
> > While I'm a bit lost with the reason of these reverts it seems we don't
> >  have solid standpoint on how this consistency check should be done. I
> >  would anticipate I'm not against this change, however I would not want
> > to alter my existing scipts (like now) in every release in order to have
> > my code working.
> > Could someone confirm this change won't be reverted in the future
> > releases?
> > Best regards,
> > Tamas
Alan Boudreault
Mapgears
http://www.mapgears.com
