[mapserver-dev] WFS BBOX on point layers
Jan Hartmann j.l.h.hartmann at uva.nl
Mon May 10 06:43:32 EDT 2010
Could this be the same problem I had with the new [shplabel] tag? There
was something wrong there when the bounding box was so small that it
degenerated into a single point when projected from world to image
coordinates. See:
http://trac.osgeo.org/mapserver/ticket/3241#comment:23
Jan
On 05/09/10 21:12, Bart van den Eijnden wrote:
> Hi list,
> when a very small BBOX filter is sent to Mapserver WFS, and the source layer is a point layer, it is very hard to actually select the point, normally no result is given.
> Does Mapserver use TOLERANCE in this particular case? I can't seem to influence the situation by increasing TOLERANCE.
> Using MS 5.4.
> TIA.
> Best regards,
> Bart_______________________________________________
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
