[mapserver-dev] WFS BBOX on point layers
Lime, Steve D (DNR) Steve.Lime at state.mn.us
Mon May 10 11:58:06 EDT 2010
I just checked the msQueryByRect() code and it doesn't seem to use tolerance. I think it should so this is a bug. The fix should be relatively simple: expand the search rect by the layers tolerance value and then proceed as normal. If you'd create a ticket and perhaps a test case I'd be happy to fix this ASAP in 5.6 and trunk...
Steve
-----Original Message-----
From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Bart van den Eijnden
Sent: Sunday, May 09, 2010 2:12 PM
To: MapServer Dev Mailing List
Subject: [mapserver-dev] WFS BBOX on point layers
Hi list,
when a very small BBOX filter is sent to Mapserver WFS, and the source layer is a point layer, it is very hard to actually select the point, normally no result is given.
Does Mapserver use TOLERANCE in this particular case? I can't seem to influence the situation by increasing TOLERANCE.
Using MS 5.4.
TIA.
Best regards,
Bart_______________________________________________
mapserver-dev mailing list
mapserver-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-dev
