[mapserver-dev] Failed to build the binary mapserver-config in Mapserver v6.4.0
thomas bonfort thomas.bonfort at gmail.com
Wed Sep 25 18:48:50 PDT 2013
Samuel,
The mapserver-config is not needed anymore by our build and will not
be supplied. As Alan said, you should check with the zoo team as to
how and when they plan to support 6.4
thomas
On 26 September 2013 03:39, samuelmesa at gmail.com <samuelmesa at gmail.com> wrote:
> Thanks for your reply Alan, I will contact with zoo-project. However, I'd
> like to know if the mapserver-config  file is not already supported or
> created in the latest versions of Mapserver.
> Thank you
> Samuel Mesa.
> 2013/9/25 Alan Boudreault <aboudreault at mapgears.com>
>> Samuel,
>> You will get better answers on the Zoo project mailing list. Does it
>> support MS 6.4.0 yet?
>> Alan
>> On 13-09-25 04:09 PM, samuelmesa at gmail.com wrote:
>>> Hello, is possible to build mapserver-config binary in the latest
>>> version of Mapserver V6.4.0, since in the compilation and install, this
>>> file does not exist. I appreciate the response, this mapserver-config
>>> file is a prerequisite to compile the zoo-project and support Mapserver
>>> [1].
>>> I used the following compilation:
>>> cmake.\
>>> -DCMAKE_INSTALL_PREFIX=  / usr /\
>>> -DPYTHON_EXECUTABLE=  / usr/bin/python2\
>>> -DPYTHON_INCLUDE_PATH=  / usr/include/python2.7\
>>> -DPYTHON_LIBRARIES=  / usr/lib/python2.7\
>>> -DWITH_CAIRO=  ON\
>>> -DWITH_CLIENT_WFS=  ON\
>>> -DWITH_CLIENT_WMS=  ON\
>>> -DWITH_CSHARP=  OFF\
>>> -DWITH_CURL=  ON\
>>> -DWITH_EXEMPI=  OFF\
>>> -DWITH_FCGI=  ON\
>>> -DWITH_FRIBIDI=  ON\
>>> -DWITH_GD=  OFF\
>>> -DWITH_GDAL=  ON\
>>> -DWITH_GENERIC_NINT=  OFF\
>>> -DWITH_GEOS=  ON\
>>> -DWITH_GIF=  ON\
>>> -DWITH_ICONV=  ON\
>>> -DWITH_JAVA=  OFF\
>>> -DWITH_KML=  ON\
>>> -DWITH_LIBXML2=  ON\
>>> -DWITH_MSSQL2008=  OFF\
>>> -DWITH_MYSQL=  OFF\
>>> -DWITH_OGR=  ON\
>>> -DWITH_ORACLESPATIAL=  OFF\
>>> -DWITH_ORACLE_PLUGIN=  OFF\
>>> -DWITH_PERL=  OFF\
>>> -DWITH_PHP=  ON\
>>> -DWITH_POINT_Z_M=  OFF\
>>> -DWITH_POSTGIS=  ON\
>>> -DWITH_PROJ=  ON\
>>> -DWITH_PYTHON=  ON\
>>> -DWITH_RSVG=  OFF\
>>> -DWITH_RUBY=  OFF\
>>> -DWITH_SDE=  OFF\
>>> -DWITH_SDE_PLUGIN=  OFF\
>>> -DWITH_SOS=  ON\
>>> -DWITH_SVGCAIRO=  ON\
>>> -DWITH_THREAD_SAFETY=  ON\
>>> -DWITH_WCS=  ON\
>>> -DWITH_WFS=  ON\
>>> -DWITH_WMS=  ON\
>>> -DWITH_XMLMAPFILE=  OFF\
>>> Regards,
>>> Samuel Mesa.
>>> [1]
>>> http://www.zoo-project.org/docs/kernel/install-unix.html#optional-mapserver-support
>>>     / v \
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
>> Alan Boudreault
>> http://www.mapgears.com/
>    / v \
