[mapserver-dev] Failed to build the binary mapserver-config in Mapserver v6.4.0
samuelmesa at gmail.com
Wed Sep 25 19:21:49 PDT 2013
Thank you Alan and Thomas for your answers.
Regards,
Samuel Mesa.
2013/9/25 thomas bonfort <thomas.bonfort at gmail.com>
> Samuel,
> The mapserver-config is not needed anymore by our build and will not
> be supplied. As Alan said, you should check with the zoo team as to
> how and when they plan to support 6.4
> thomas
> On 26 September 2013 03:39, samuelmesa at gmail.com <samuelmesa at gmail.com>
> wrote:
> > Thanks for your reply Alan, I will contact with zoo-project. However, I'd
> > like to know if the mapserver-config file is not already supported or
> > created in the latest versions of Mapserver.
> > Thank you
> > Samuel Mesa.
> > 2013/9/25 Alan Boudreault <aboudreault at mapgears.com>
> >> Samuel,
> >> You will get better answers on the Zoo project mailing list. Does it
> >> support MS 6.4.0 yet?
> >> Alan
> >> On 13-09-25 04:09 PM, samuelmesa at gmail.com wrote:
> >>> Hello, is possible to build mapserver-config binary in the latest
> >>> version of Mapserver V6.4.0, since in the compilation and install, this
> >>> file does not exist. I appreciate the response, this mapserver-config
> >>> file is a prerequisite to compile the zoo-project and support Mapserver
> >>> [1].
> >>> I used the following compilation:
> >>> cmake.\
> >>> -DCMAKE_INSTALL_PREFIX= / usr /\
> >>> -DPYTHON_EXECUTABLE= / usr/bin/python2\
> >>> -DPYTHON_INCLUDE_PATH= / usr/include/python2.7\
> >>> -DPYTHON_LIBRARIES= / usr/lib/python2.7\
> >>> -DWITH_CAIRO= ON\
> >>> -DWITH_CLIENT_WFS= ON\
> >>> -DWITH_CLIENT_WMS= ON\
> >>> -DWITH_CSHARP= OFF\
> >>> -DWITH_CURL= ON\
> >>> -DWITH_EXEMPI= OFF\
> >>> -DWITH_FCGI= ON\
> >>> -DWITH_FRIBIDI= ON\
> >>> -DWITH_GD= OFF\
> >>> -DWITH_GDAL= ON\
> >>> -DWITH_GENERIC_NINT= OFF\
> >>> -DWITH_GEOS= ON\
> >>> -DWITH_GIF= ON\
> >>> -DWITH_ICONV= ON\
> >>> -DWITH_JAVA= OFF\
> >>> -DWITH_KML= ON\
> >>> -DWITH_LIBXML2= ON\
> >>> -DWITH_MSSQL2008= OFF\
> >>> -DWITH_MYSQL= OFF\
> >>> -DWITH_OGR= ON\
> >>> -DWITH_ORACLESPATIAL= OFF\
> >>> -DWITH_ORACLE_PLUGIN= OFF\
> >>> -DWITH_PERL= OFF\
> >>> -DWITH_PHP= ON\
> >>> -DWITH_POINT_Z_M= OFF\
> >>> -DWITH_POSTGIS= ON\
> >>> -DWITH_PROJ= ON\
> >>> -DWITH_PYTHON= ON\
> >>> -DWITH_RSVG= OFF\
> >>> -DWITH_RUBY= OFF\
> >>> -DWITH_SDE= OFF\
> >>> -DWITH_SDE_PLUGIN= OFF\
> >>> -DWITH_SOS= ON\
> >>> -DWITH_SVGCAIRO= ON\
> >>> -DWITH_THREAD_SAFETY= ON\
> >>> -DWITH_WCS= ON\
> >>> -DWITH_WFS= ON\
> >>> -DWITH_WMS= ON\
> >>> -DWITH_XMLMAPFILE= OFF\
> >>> Regards,
> >>> Samuel Mesa.
> >>> [1]
> http://www.zoo-project.org/docs/kernel/install-unix.html#optional-mapserver-support
> >>> / v \
> >>> _______________________________________________
> >>> mapserver-dev mailing list
> >>> mapserver-dev at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> >> Alan Boudreault
> >> http://www.mapgears.com/
> > / v \
/ v \
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20130925/2a476e6b/attachment-0001.html>
