[mapserver-dev] updated Backport workflow
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Apr 4 09:54:28 PDT 2020
Hi Devs,
Today I spent some effort on configuring a new Backport process,
leveraging the same tool that is now relied upon heavily by several
other projects such as QGIS, etc.  The big change now is that the
backport bot is triggered by setting one of the "backport ..." *LABELS*.
  Here is an example workflow:
  - create PR to master
  - then add one of the new "backport..." labels such as "backport
branch-7-6" to the PR
  - when merged the bot will automagically create another PR to that branch
Here is an example PR, notice the label set in right panel:
https://github.com/mapserver/mapserver/pull/6035
..which when merged magically generated a PR into branch-7-6:
https://github.com/mapserver/mapserver/pull/6036
Let me know if anything needs modifying in the process, which is fully
configured in the file:
https://github.com/mapserver/mapserver/blob/master/.github/workflows/backport.yml
Give it a try and let me know,
-jeff
