[mapserver-dev] updated Backport workflow
    Jeff McKenna
    jmckenna at gatewaygeomatics.com
    Sat Apr  4 09:56:50 PDT 2020
As of right now here are the associated labels that you can choose from:
   backport branch-6-4
   backport branch-7-4
   backport branch-7-6
-jeff
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
On 2020-04-04 1:54 p.m., Jeff McKenna wrote:
> Hi Devs,
> Today I spent some effort on configuring a new Backport process,
> leveraging the same tool that is now relied upon heavily by several
> other projects such as QGIS, etc.  The big change now is that the
> backport bot is triggered by setting one of the "backport ..." *LABELS*.
>   Here is an example workflow:
>   - create PR to master
>   - then add one of the new "backport..." labels such as "backport
> branch-7-6" to the PR
>   - when merged the bot will automagically create another PR to that branch
> Here is an example PR, notice the label set in right panel:
> https://github.com/mapserver/mapserver/pull/6035
> ..which when merged magically generated a PR into branch-7-6:
> https://github.com/mapserver/mapserver/pull/6036
> Let me know if anything needs modifying in the process, which is fully
> configured in the file:
> https://github.com/mapserver/mapserver/blob/master/.github/workflows/backport.yml
> Give it a try and let me know,
> -jeff
