[mapserver-dev] Fwd: [mapserver/mapcache] Berkeley DB - BDB0058 illegal page type or format (#226)
Jérome Boué jbo-ads at laposte.net
Thu Feb 6 23:15:41 PST 2020
Has somebody any clue on this issue? I am not familiar with Berkeley DB.
Jérome.
-------- Forwarded Message --------
Subject: 	[mapserver/mapcache] Berkeley DB - BDB0058 illegal page type
or format (#226)
Date: 	Mon, 03 Feb 2020 02:02:59 -0800
From: 	asteinereurofunk <notifications at github.com>
Reply-To: 	mapserver/mapcache
<reply+AIZNBQGCLNNXIU6SCHKWGUV4IURFHEVBNHHCCUJ7PU at reply.github.com>
To: 	mapserver/mapcache <mapcache at noreply.github.com>
CC: 	Subscribed <subscribed at noreply.github.com>
Hello, I have a problem when seeding into a Berkeley DB Cache:
The following error occours:
*seeded 960 tiles, now at z18 x1032 y68
BDB0058 page 696120: illegal page type or format
BDB0061 PANIC: Invalid argument
BDB0060 PANIC: fatal region error detected; run recovery
BDB1581 File handles still open at environment close
BDB1582 Open file handle: /tmp/mapcache/OSM/__db.001
BDB1582 Open file handle: /tmp/mapcache/OSM/__db.002
BDB1582 Open file handle: /tmp/mapcache/OSM/__db.003
BDB1582 Open file handle: /tmp/mapcache/OSM/OSM.db
failed to seed tile z18,x1020,y68:
dbd backend failed on tile_multiset: BDB0087 DB_RUNRECOVERY: Fatal
error, run database recovery*
After I stopped the seeding process I deleted the temp files (__db.00x).
Then I watched the WMS source with QGIS. When I look at a not seeded
tile, mapcache is seeding it successfully and the cache is getting bigger.
Then start the seeding process again and after some tiles the error :
*BDB0058 page 696120: illegal page type or format* occurs again.
Restarting Mapcache doesnt help.
You are receiving this because you are subscribed to this thread.
Reply to this email directly, view it on GitHub
<https://github.com/mapserver/mapcache/issues/226?email_source=notifications&email_token=AIZNBQATBIVYKK35TMHKGI3RA7TVHA5CNFSM4KPCI3G2YY3PNVWWK3TUL52HS4DFUVEXG43VMWVGG33NNVSW45C7NFSM4IKRH56Q>,
or unsubscribe
<https://github.com/notifications/unsubscribe-auth/AIZNBQHCNB2LN3AER7MKTODRA7TVHANCNFSM4KPCI3GQ>.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200207/a16af577/attachment.html>
