[mapserver-dev] Fwd: [mapserver/mapcache] Berkeley DB - BDB0058 illegal page type or format (#226)
Steve Lime sdlime at gmail.com
Fri Feb 7 07:51:37 PST 2020
Probably need information on the versions of everything MapCache, OS and
especially BDB. This is the first issue I can recall seeing related to BDB
although I'm not sure how popular it is as a backend.
On Fri, Feb 7, 2020 at 1:15 AM Jérome Boué <jbo-ads at laposte.net> wrote:
> Hi,
> Has somebody any clue on this issue? I am not familiar with Berkeley DB.
> Jérome.
> -------- Forwarded Message --------
> Subject: [mapserver/mapcache] Berkeley DB - BDB0058 illegal page type or
> format (#226)
> Date: Mon, 03 Feb 2020 02:02:59 -0800
> From: asteinereurofunk <notifications at github.com>
> Reply-To: mapserver/mapcache
> <reply+AIZNBQGCLNNXIU6SCHKWGUV4IURFHEVBNHHCCUJ7PU at reply.github.com>
> To: mapserver/mapcache <mapcache at noreply.github.com>
> CC: Subscribed <subscribed at noreply.github.com>
> Hello, I have a problem when seeding into a Berkeley DB Cache:
> The following error occours:
> *seeded 960 tiles, now at z18 x1032 y68 BDB0058 page 696120: illegal page
> type or format BDB0061 PANIC: Invalid argument BDB0060 PANIC: fatal region
> error detected; run recovery BDB1581 File handles still open at environment
> close BDB1582 Open file handle: /tmp/mapcache/OSM/__db.001 BDB1582 Open
> file handle: /tmp/mapcache/OSM/__db.002 BDB1582 Open file handle:
> /tmp/mapcache/OSM/__db.003 BDB1582 Open file handle:
> /tmp/mapcache/OSM/OSM.db BDB0060 PANIC: fatal region error detected; run
> recovery BDB0060 PANIC: fatal region error detected; run recovery BDB0060
> PANIC: fatal region error detected; run recovery BDB1581 File handles still
> open at environment close BDB1582 Open file handle:
> /tmp/mapcache/OSM/__db.001 BDB1582 Open file handle:
> recovery failed to seed tile z18,x1020,y68: dbd backend failed on
> tile_multiset: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery*
> After I stopped the seeding process I deleted the temp files (__db.00x).
> Then I watched the WMS source with QGIS. When I look at a not seeded tile,
> mapcache is seeding it successfully and the cache is getting bigger.
> Then start the seeding process again and after some tiles the error : *BDB0058
> page 696120: illegal page type or format* occurs again. Restarting
> Mapcache doesnt help.
>> You are receiving this because you are subscribed to this thread.
> Reply to this email directly, view it on GitHub
> <https://github.com/mapserver/mapcache/issues/226?email_source=notifications&email_token=AIZNBQATBIVYKK35TMHKGI3RA7TVHA5CNFSM4KPCI3G2YY3PNVWWK3TUL52HS4DFUVEXG43VMWVGG33NNVSW45C7NFSM4IKRH56Q>,
> or unsubscribe
> <https://github.com/notifications/unsubscribe-auth/AIZNBQHCNB2LN3AER7MKTODRA7TVHANCNFSM4KPCI3GQ>
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20200207/da81432a/attachment-0001.html>
