[mapserver-dev] mapcache/demo is not working over https
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Feb 13 07:26:42 PST 2020
The related change: https://github.com/mapserver/mapcache/pull/192
-jeff
On 2020-02-13 11:22 a.m., Jeff McKenna wrote:
> Hi Steve,
> I remember that we fixed this issue, in the past year, for MapCache.  If
> you try with MapCache-master (or 1.10.0-rc1) this should work for you.
> For example, the official MS4W demo server is HTTPS, and you can see the
> demo working (with MapCache-master) at https://ms4w.dev/mapcache/demo/
> Hope that helps, and cheers from the east coast of Canada,
> -jeff
> On 2020-02-13 11:17 a.m., Stephen Woodbridge wrote:
>> Hi all,
>> Trying to debug another issue, I just ran into a problem with
>> mapcache/demo is not working over https because it is trying to load
>> http://openlayers.org/api/OpenLayers.js which is causing:
>> Blocked loading mixed active content
>>http://www.openlayers.org/api/OpenLayers.js”
>> It looks like the www.openlayers.org server is redirecting to https
>> but I think the problem is in the initial request.
>> Browser is latest firefox
>> server is ubuntu 18.04
>> mapcache is 1.6.1-1
>> -Steve W
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
