[mapserver-dev] Proposed RFC 129: Update msautotest to use Pytest
Seth G sethg at geographika.co.uk
Wed Jan 29 13:45:07 PST 2020
Hi Even,
Is it an option to get rid of the msautotest Python tests completely by moving them to the Python MapScript test suite?
As part of the update to SWIG 4 I had to fix one of the styleObj tests so moved it with the other style tests (see https://github.com/mapserver/mapserver/pull/5983).
Are there special cases where tests couldn't be moved to mapscript/python/tests/cases? The move to pytest (which the Python MapScript tests also use as a test runner) certainly helps any migration so +1 on this in any case.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Wed, Jan 29, 2020, at 7:08 PM, Even Rouault wrote:
> Hi,
> Please find at
> https://mapserver.org/development/rfc/ms-rfc-129.html
> a RFC that proposes updating msautotest to use the Pytest framework
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
